iPhone 13 Series
PetPet
Moderator
Moderator
U can tell which field after accessing this hidden menu?
The interface on iOS 14 and 15 is different
On iOS 14, I think you'll need to drill down to RAT -> Cell Info -> Radio Access
On iOS 15. It'll state —
Op_Valkyrie
Bro, u lost me in outer space. Haha
My monitoring - what to look out for?
PetPet
Moderator
Moderator
So meaning not 5G SA right? Actually now iPhone don support 5G SA only 5G NSA?
From Singtel white paper https://www.singtel.com/content/dam/singtel/personal/products-services/mobile/5g/Singtel 5G FAQ_250521.pdf
Singtel in SG is mostly blanketed in 5G NSA.
If you want to look for 5G SA, you need to go to specific areas.
Singtel said:
5G SA and deployed over a thousand 5G sites across Singapore in strategic locations such as Orchard Road, the Central Business District, Marina Bay, Harbourfront and Sentosa, as well as major residential areas including Sengkang, Punggol, Pasir Ris, Jurong East, Woodlands, and more.
https://www.singtel.com/about-us/me...-in-singapore-to-launch-5g-standalone-network
To be able to access the 5G SA network you need a SIM Card that is issued after 27 April 2021 (I got this date from when the article was written, https://www.hardwarezone.com.sg/tec...etwork-deployment-issues-5g-sa-sim-cards-free)
Correct me if I'm wrong. But there's no reason to not support iPhone with the SA tech since Singtel 5G SA sites run on 3.5 GHz spectrum.
Which, the iPhone supports https://www.apple.com/sg/iphone/cellular/
Edit — To add on, this is the post that shows the SA speed tests.
https://forums.hardwarezone.com.sg/threads/iphone-12-series.6392525/post-134788962
Op_Valkyrie
Your reasoning sounds logical on the spectrum part. But does Singtel needs to push any telco profile to the phone for this to happen? It’s weird that their white paper mention not compatible with 5G SA for all current iPhone models.
DPR_Reborn
I understand that all 3 telcos 5G SA is on the same spectrum, does the iPhone 13 sold in SG, support it aka SA? I know mmWave is still limited to US models. Could someone help confirm?
PetPet
Moderator
Moderator
Well, I have "5G" right now. But I don't think I'm willing to pay 40 bucks to upgrade to SA.
Haha for NSA, the KCTCellMonitorDeploymentType appears to be (4).
You'll need to trial and error a little to figure if you're on SA.
Op_Valkyrie
I’m also curious on this portion. Hmm….
Op_Valkyrie
Wth…. Make things so complicated on the end user side. I’m also on 5G NSA…. Speed like crap…. Not much differ from LTE
PetPet
Moderator
Moderator
5G is all marketing.
It's all fluff and hype.
There's no difference to 4G, you'll not notice it unless you're like playing eSports or require some latency sensitive stuff.
When 4G rolled out, there wasn't even so much marketing because you could clearly identify the speed increase.
With 5G, it feels exactly the same.
I say, don't worry about these. Just use it and enjoy.
Op_Valkyrie
The reason I’m asking is because I’m not sure if I should change my current nano sim to the new SA nano sim. Like no benefit since iPhone 13 can’t leverage. Also I’m on 5G Now plan since last year, not sure if I should still continue. Hmm….
ragnarok95
Senior Moderator
Senior Moderator
Ask. If its free.... just change. lol. New phone new casing, new SP, new sim. lol. :D
*adiBOY
Don’t forget 5G consume more power too, more so if the 5G signal is weak and it keeps dropping back to 4G.
Tukatuz
