iPhone 13 Series
samgoh87
Took the plunge and ordered 13pro s.blue last night too! Gave up on ordering via M1 website. Lol… 6 more days to go for collection ~~
Windowlover
Anyone know 5G mmwave means ? It is able to connect to SG network for future 5G mobile.
Op_Valkyrie
Sorry bro thought I should clarify.
I dabbled around and found that the menu shifted a little in iOS15
to find out if you have 5G SA or NSA.
Punch in that code.
Make sure to be on a 5G network.
Under the 5G section > Tap on NR ConnectionStats > Look for connection Type
Or refer to my Screenshot.
Good luck in hunting for SA!
Remember to do speed test and let us know results hehe.
Bro I can’t find the connection_type under iOS 15. Weird…
szeli
the batt improvement is quite significant compared to iPhone 12 🤔
the below is streaming performance, 13 mini is better than 12 pro max
masashi
Wow 12 to 25 hours from 12PM to 13PM :eek: scary sia.
tjkb230
Guess is due to improved displays and variable frame rate feature. If current phones are refreshing at 60Hz, and the videos are playing at 30Hz, then iPhone 13 Pro/Pro Max can just refresh the display at 30Hz as well (given that area outside video is static.
It was explained that if the whole display is static, the frame rate is just 10 Hz. Upon touchscreen detects tap, the frame rate will increase and it will adjust according to how the screen moves according to the 'inertia' (like the page continues to move after you lift your hand off the screen).
After everything transfer over to new phone, do we need to reinput the credentials like banks, email accounts and game?
lordleslie
Anyone want to trade Apple iPhone 13 Pro 512GB Sierra Blue for Apple iPhone 13 Pro MAX 512GB Sierra Blue?
Will pay the difference
