iPhone 13 Series
i.Singaporean
Guess is due to improved displays and variable frame rate feature. If current phones are refreshing at 60Hz, and the videos are playing at 30Hz, then iPhone 13 Pro/Pro Max can just refresh the display at 30Hz as well (given that area outside video is static.
It was explained that if the whole display is static, the frame rate is just 10 Hz. Upon touchscreen detects tap, the frame rate will increase and it will adjust according to how the screen moves according to the 'inertia' (like the page continues to move after you lift your hand off the screen).
Not really, most of it is probably due to the efficiency of the new A15
The non-Pro 13 does not have ProMotion yet the battery life is dramatically improved too
Jirachi
the batt improvement is quite significant compared to iPhone 12 🤔
the below is streaming performance, 13 mini is better than 12 pro max
Theoretical numbers. Let's wait for the real world tests when the phones are ready.
Jirachi
After everything transfer over to new phone, do we need to reinput the credentials like banks, email accounts and game?
Sensitive stuff like 2FA token might have to re-do. Depending on individual applications too.
Email accounts, I believe just need to re-enter the passwords.
Apple Pay is confirm a must.
friedapple
Sorry for the dumb questions but hope someone can help to answer:
1) we can place order as delivery on the apple site but cancel it and place a new order again if we see stocks available right?
2) if we want to do engraving, is it definitely will need to opt for delivery and not pick up (even if available)?
New to this so sorry for the noob questions.
Thanks!
PetPet
Moderator
Moderator
Thanks!
1. Yes, provided your order has not been shipped.
2. Engraving option is not available for iPhones.
*adiBOY
A15 efficiency and iOS 15 optimization are doing all the work to consume less power. Coupled with the fact the battery capacity are larger across all iPhone 13 models.
iPhone 13 has a higher capacity battery compared to iPhone 13 Pro but iPhone 13 Pro has a better battery life over the iPhone 13 so Pro Motion is also helping with the battery life on the Pro models.
Email is bit dependent on what’s the mail client you’re using. If you’re using the Native Mail app. It should not require any changes
  • Face ID
  • Apple Pay
  • All Bank 2FA
thanks for the reply
friedapple
Thanks for the fast reply! I was thinking of ordering the ipad 9 and then the phone too. Was thinking if I order ipad 9 and engrave it would I need to have it delivered instead of self collect. Thanks
jackycar
The casing for iPhone 12 pro max and 13 pro max same dimensions? I put a 13 pro max case on my 12 pm seems to work find
Ye_Rongtian
13 is thicker and camera area bigger than 12. Of cos it seem to work fine. Put your 12 into a 13 case and it will not fit.
