iPhone 13 Series
runforyourlife
Moderator
Moderator
use a 60hz ipad and u will surely notice haha. 60hz on a big screen is very noticeable compared to phones
That’s the prob. If you never compare you won’t even feel the diff.
Like never drive conti car before dunno how it feels ba.
unless backside itchy den buy to cure the itch lo.
derkaiser94
Ya lo, cure itch is expensive de. No see no problem.
good hor. i always envy those with the eat to survive mentality, no need to spend extra on foods that are nice.
Similarly if you can't tell the difference with higher refresh rate screens, can jolly well save the extra coin and enjoy old tech without even being aware of any differences. shoik
paul02
The moral of the story here is: Experience is subjective.
Some will try and notice the 120Hz difference but can live with 60Hz, they can adapt. Those who can't just pay the premium for it.
lumpyme
has anybody tested the iphone 13 pro motion before? is it as smooth as the samsungs?
samsung doesn't bring the fps down to 1hz like the iphone does and the effect is buttery smooth
not sure if iphone can achieve the same effect, especially when the 13 has more battery than the 13 pro, the normal 13 seems to be the better choice
lumpyme
i put an iphone 12 pro max and a samsung s21u together and tested, it is very obvious that the samsung is more smooth than the iphone 12 pro max
wonder if the iphone 13 pro can match the samsung, i'm more keen on the pro not the pro max
runforyourlife
Moderator
Moderator
New tech is a want.
Having the best tech doesn't bring up one's self esteem unfortunately.
Can afford a cellphone not equal to rich :s22:
