silentears
- Jun 29, 2008
wah u have the confidence to pull of this type?This kind of side cut is called what ah?
low/mid fade?
low/mid fade?
depending on face shape. whats your face shape like? round? long?pretty new to this.
any tldr guide on choosing a particular style and how to choose the correct wax/hairspray/sea salt for correct styling?
ash grey jin secksi- if dye hair can what sort of colour can be accepted in sg ah generally speaking? ash brown?
any particular hairstyle u have in mind (show pic)?i tried to grow hair longer, become no shape and side very puffy like mushroom. while infront fringe too long become very heavy as quite straight, do ppl usually make fringe go up?
probably sharp..never really beo facedepending on face shape. whats your face shape like? round? long?
ash grey jin secksi
ask grey how to work
hairstyle no, current one is puffy mushroom sidepart lo
ur pic that hairstyle is side cut is called undercut la
https://menshaircuts.com/undercut-styles-guide/
then i not sure liao for the undercutMushroom sidepart like this? jin satki mens tears dd
no lah undercut is shave all the way up de, one length for the entire side. that one top part longer, bottom part short
actually tears dd ish quite yandao wor, chiu pretend not handsum onlythen i not sure liao for the undercut
something like that la, the photo dude got permed hair. but mine is straight... thats why look very untidy when the top is flat/ side poof out/fringe hits my spectacles
ash grey looks not bad though.. u ash grey ah? must be hamsum to pull off
... Who said I was yandao. I bbfa uglyactually tears dd ish quite yandao wor, chiu pretend not handsum only
i dont dare dye my hair and damage it, cos my hair volume not there alr mine is natural black
Npnt got chance Chiu more handsome than me... Who said I was yandao. I bbfa ugly
Ya dye hair will spoil.
Old Liao hair volume lower is normal.m
bumps. anyone knows?This kind of side cut is called what ah?
low/mid fade?
eh so what products u use?Npnt got chance Chiu more handsome than me
This is nothingwah u have the confidence to pull of this type?
This is true... Who said I was yandao. I bbfa ugly
sounds like something i'm looking for. could you share the exact name of the product you're using? just indians molding clay?
Tried the Indians molding clay from bro Jun Hong and I finally found something suitable for my fine hair. Being a clay, it's not as easy to run through your hair like MM but it's light and holds the hair well, unlike MM which is heavy when apply and holds my hair down after some time.
After applying Indians molding clay, finish off with hair spray helps me last throughout the day!
You can try to search for Indians Extra Strong Hold Molding Clay. It is available on different platforms but from the same seller.sounds like something i'm looking for. could you share the exact name of the product you're using? just indians molding clay?
and what hair spray are you using may i know
Think either take the minoxidil or go hair transplant could give better results.Ask u all ah, those hair treatment for thinning / balding hair like yun nam, beijing 101, jean yip all no use one right?
if i am rich i would have considered transplantThink either take the minoxidil or go hair transplant could give better results.
