iPhone13/Mini/Pro/Pro Max Accessories Showcase Thread
Snoweagle
The camera bump is definitely smaller on 13 as compared to the Pro series.
Why on earth did you buy a 13 Pro case for 13? If compatible, Apple wouldn't release cases for the 13 and 13 Pro separately.
nagase_4
Mine is iPhone 13, but i ordered Apple Leather Case for iPhone 13 Pro instead.
are they compatible or do i have to go exchange?
alamak sia!!
Update - Just called up Apple. They say should fit. I can wait till i recieve my phone tmr and try it on. If it doesnt fit, can call them back and ask for refund.
Anybody staying west side wanna buy over?
Color is Sequoia Green,
*adiBOY
alamak sia!!
Both are different leh how to fit?!
frizee
alamak sia!!
Save the headache and worry, cancel and order the correct one for 13, i see self collect can be done today. :)
HZYiLong
even coating no gone also easy get scratches for spigen. their quality seem to drop liao. last time their TG very very smooth one
Last time really good, but now like cut corners earn profits. I stopped using them since iPX.
night87
Bros, any recommendation for Film type screen protector ? Dont really prefer TG screen protectors.
Thanks.
mikeeeey
alamak sia!!
Update 2 - Re-ordered the correct case. Gonna send this wrong case back via mail and request for refund (according to their Apple Customer Care). Unless anyone here wanna buy over.
After seeing your message i go check my purchase again to be sure 😅
