Nakedtoes
- Dec 9, 2002
Both a need?Seem the non pro version do not have GPS. Only pro version has GPS and finger print sensor.
Think GPS is more important.Both a need?
Don't expect on global pro version because may not launch at all. No GPS but you still can locate positioning they WiFi. Just that not accurate only.Think GPS is more important.
Not sure when will pro version arrive.
That's the problem.Don't expect on global pro version because may not launch at all. No GPS but you still can locate positioning they WiFi. Just that not accurate only.
Saw some YouTube reviewer showed before. You may Google it.Guys with the Mi Pad 5/5Pro can you test Floating windows/drawing over other apps? Does it work on the Mi Pad?
My order says delivery date between 30 Sep to 9 Oct.Those who have managed to order from official Xiaomi Lazada.
What is the Delivery Date?
Sep.25 12:33
Departed from Logistics Facility
Your parcel has departed the logistics facility from China
Snapdragon 860 is way weaker than A15 though.I had a feel with the Mi Pad 5 in Xiaomi store today. Super smooth and super fast. Very shiok to use compared with the new iPad mini.
Probably cos you're more familiar with the Android interface?I had a feel with the Mi Pad 5 in Xiaomi store today. Super smooth and super fast. Very shiok to use compared with the new iPad mini.
I think it's the difference in refresh rate. The display on the Xiaomi pad is 120hz while the one on the ipad mini is only 60hz.Probably cos you're more familiar with the Android interface?
