iPhone 13 Series
jackycar
Anyone using apple watch cellular and 5g on m1 iPhone successfully? Quite lame that m1 doesn't allow number share and 5g together?
raindance
The only thing right now stopping me from buying an iphone is the lack of touch ID. i don't think i can live without it. everywhere need TT check in, so you guys w/o apple watch need to key in passcode everywhere???
jackycar
Just talked to m1. Was told that "5g coverage not stable. Recommend u switch to 4g first if your data having issues".
THEN I GET RID OF MY ESIM. LOSE MY DUAL SIM. AND GET 5G SIM CARD FOR WHAT? TO SET MY PHONE TO 4G?
I doolan alr. Call into m1 and told them pls let me terminate. I port to singtel where I can use 5g and numbershare on my apple watch no issues. Pls waive my early termination charges.
Then earlier. I called in to another cso before this one. He told me he will cancel my number share for my Apple Watch..then "enable it on my wife's line" so it can tag to my apple watch.
I asked won't thst cause my wife's phone calls to go to my apple watch? Oh no no it won't it's just a data thing.
Knn I called again to the cs they told me it's not possible to initiate number share from m1 side cause u need to do it from the Apple Watch app.
If wife not using apple not possible at all.
Even if wife using apple. It would tag to her number.
****ing 3 times in a row cluster **** of info
Last CS told me oh could be that the Apple Watch and iPhone using different types of 4g or 5g bands. This 5g and numbershare doesn't work for this new iPhone.
I'm like... Then why singtel can?
Jirachi
After watching this video. I think the only reason now why i will buy 13PM is for the 120hz display. But who knows, maybe i will end up replacing my 12PM after all.
Wait, so you are still holding on to your 12 Pro Max?
Hi, how could we use our iPhone 13PM to toggle the Bluetooth by back tapping the iPhone. As we may need to turn on and off the Bluetooth quite often nowadays.
You might want to try using the Shortcuts app and create an automation to toggle your Bluetooth.
i believe there are 2 points in the video that make us watch throughout the video. LOL
Well, you got a point there ;)
Won’t
I always leave NFC and BT on even when sleeping
Take public transport is so convenient,just tap nia
Wait... Is the Express Travel Card working now? Because the way you describe it seemed to be the feature.
wira
how much battery life are you able to save from turning off & on? are you those who sign in/out trace together, then turn off Bluetooth ?
dont think makes a lot of difference to batt life.
and turning off BT will disable TT tracing right which defeats the purpose of the app to protect you as well if you are exposed
Richliao
maybe he has the token on him., and personally i think TT really has an impact on battery, at least with my present S21 Ultra.
vuzuuu
I was at a petrol station to make payment last week and I saw this guy in front of me to flash his iPhone to the cashier which shows a POSB EVERYDAY credit card. How could I activate this POSB EVERYDAY credit card figure on my iPhone if I would like to make payments thru paywave on my iPhone instead the physical credit card ??
Jirachi
Just add your CC via the Wallet app?
Snoweagle
Go to the Wallet app and add your credit card. Once activated, you can use it already by double-clicking the side button of your iPhone.
1982-1994
Prolong double clicking might spoil the side button ,hence I stopped using it thanks to the tap to wake function
Went back to using physical card
If only can just tap the phone for payment just like android phone
zorrus
Moderator
Moderator
hi i just setup my iphone 13PM, and i noticed that i can do a IOS15 update.
should i do the update?
szeli
I’ve been double clicking my side button on my X for almost 4yrs it’s still there. dun have irrational fear. it’s for security purposes. android can just tap without security? 😧
Snoweagle
I use SimplyGo on both iOS and android, but on iOS I use my Apple Watch instead, also double-clicking the power button.
