iPhone 13 Series
Jirachi
Prolong double clicking might spoil the side button ,hence I stopped using it thanks to the tap to wake function
Went back to using physical card
If only can just tap the phone for payment just like android phone
Double-clicking the button is fine. I have been clicking mine since 11 Pro Max time.
As for the Android one, that is straight up a security flaw and is a no-no for me.
tec_geek
And updating it now.
1982-1994
Noooooo I will never update it
Unless iOS does the update automatically despite of the setting
1982-1994
Have to double click twice (4x)to get through the gantry right?
So 8x to and from?
1982-1994
didn’t know toggling the wifi from the control Center does not turn off the wifi completely
anthonygreenisreal
any lobang to get applecare plus? should i get anot? lol
If you change your phone every year then no need, just get good case and screen protector.
if you like to anyhow throw phone or got butter finger or use your phone without case then should get.
in fact I think for most people no need to get applecare plus.
vuzuuu
My iphone 13PM was charged to 93% last night and I turned on airplane mode before I went to bed. Early this morning I checked the battery status and it dropped to 91% which never happened on my last 12PM. Worst thing yet to come, I browse and checked my email for about 10mins, the battery dropped again to 88%.
Did anyone has the same encountering? Is there any settings which I need to turn off in order to save my iphone battery from draining off so easily??
Chevalier
question, I’m on the 255gb 13 pro. battery life is good but not great like a lot of reviewers are claiming it to be.
I transferred my data from iPhone X to the 13 pro.
should I format and setup as new?
Read HWZ Forum Rules!
1982-1994
Personally,I don't need the refresh background apps to be on ,don't need Siri since my pronunciation not zai,and I manually off each app in Siri learning,tedious
Have you explored each and every option under the setting?
Testing the overnight battery drain on mine for 8h till 1130am ,hope it's a 2% drop too since I never turned on airplane mode
Shall share more later
1982-1994
I always believe setup as new is the best
Yes installing the apps and exploring the settings again is tedious ,but it's worth it if battery life matters to you
1982-1994
You just need to click 2x
Steps of using a card:
1. Hand goes to pocket
2. Take out the card
3. Tap it on the reader
All in 2 secs,no security since anyone can use it should it goes missing
Apple pay:
1. Face ID your phone
2. Tap it on reader
3. Double click home button
4. Authenticate
5. Double click home button again
All in like above 5secs, all for security
Those above steps were what I did,please correct me if I am wrong
Google pay:
1. Just wake up the phone, even in lockscreen
2. Tap it on reader
Maybe even faster than using a card but compromise on security
Unless you're a very careless person who always lose your personal belongings, don't find apple pay is worth the hassle
vuzuuu
Thanks bro, try to turn off the background refres mode and will continue to monitor.
