iPhone 13 Series
1982-1994
Strange. I dun feel any heat when using Brave browser for example 30 mins of youtube watching and surfing hwz. Are u on the latest 15.0.1? I am using Apple leather case btw.
Never update
Trying it again
Anyway is there an app to show the temperature of the CPU of the phone?
Kusanagi
I am using safari mostly so that is on top
dont check for battery % but the amount of time spent running in background
dont look at the whole block as well, look at the interval and see what are the recurring apps other than safari
anthonygreenisreal
Is it advisable to just get the IP13 non-pro version?
this one of coz if you can just get the pro. But if budget is a constrain, then the regular 13 also damn decent. Its like iPhone 12 Pro max camera with iPhone 12 body with brighter screen and longer battery life and upgraded processor.
I foresee, it's gonna be the best seller iPhone again like the 12, 11 and XR.
tohchr
Never update
Trying it again
I had yet come across an app that could measure cpu temperature. If there's one, those youtuber wouldn't be using an infra scanner to scan their iphone temperature during the video?
tohchr
I find the back of the phone warm ,is it normal?
Browsing safari and listen to music on headphone
Did u install Trace Together? If yes, can u temporary remove the bluetooth permission from trace together? Go to settings, scroll all the way down to look for trace together, under the Bluetooth, turn it off. This will prevent bluetooth from connecting to other devices since u using headphone which I suppose it's connected via bluetooth. Then see whether does it still heat up?
iamgaara
Can anyone advice how can I disable the swiping right to access the widget screen when the screen is locked, while keeping the option to swipe left to access camera?
tohchr
Go to Settings on your device > Face ID & Passcode > enter your passcode > scroll down to the Allow access when locked section > disable the toggle next to Today
