Xiaomi Mi Pad 5
bauer24
I have Disney + but dont know how to check.
If you can list down the steps then maybe I can help.
Mine is China ROM btw.
I'm not sure if this is the (correct) way to judge, but could you go into Disney+ and load up any 4K title like maybe Loki or Lion King.
Play it, and see if it's HD quality (at least), or comes out like crappy SD.
Also, does Netflix work in Widevine L1 for you?
This is Netflix on my tablet. I don't have Disney plus so can't test.
Power bro. Is this Xiaomi Pad 5 or Pad 5 Pro 5G? (ie global or China ROM)?
RaiderXXX
I just check my Disney Plus and can only play in HD mode.
I go to the UHD and look for those movie, when I select that movie, first page detail show is in HD.
As for Netflix, I do not have a account to test.
lbcben
today searching carousell , lazada, shopee, found this sticker sticker on "claim to be local set with local xiaomi warranty"
is this really local set, or china set?
rebornsoul
all sets with EIN stickers are global sets.
rebornsoul
my Mi Pad 5 is global set with global rom
lbcben
https://m.qoo10.sg/gmkt.inc/Mobile/Goods/Goods.aspx?goodscode=699455992&banner_no=1305330 (At SLS, $409)
https://m.qoo10.sg/gmkt.inc/Mobile/Goods/Goods.aspx?goodscode=679598654&stcode=77&banner_no=1305330 (At Hougang, $405)
The $40 is coupon, need to collect inside app, tap 2nd tab to access the page.
Remember to utilise the 500 Qoopoints to offset another $5 off if you have any.
I never buy from qoo10....for this $40 cashback
is it I have to fully paid $449, then come back, to this link, to click that $40 cashback?
andrewkb
Got a minor bugbear question. The status bar shows morning, afternoon depending on time of the day. Its taking up my status bar space 😅 anyone figured how to remove it?
PES1989
Yes, you are correct if you are referring to the Grab $40 cashback. But the Qoo10 $40 coupon can be use to offset the $449.
1-wind
I cannot find as well.
What bugs me more is the Google app icons like Gmail, Drive, Photos are the old ones. o_O
rebornsoul
go to settings, additional settings, date and time, change format to 24 hour. That's the only way.
kelvinti
MIUI gurus,
How to disable the Search function when we swipe up from the bottom of display in MIUI 12.5x? :unsure:
I find it super duper irritating..:poop:
I couldn't find any selection? :unsure:
Don't tell me must adb to remove? :unsure:
rebornsoul
MIUI gurus,
:unsure:
:poop:
:unsure:
:unsure:
I removed by installing this app. After disabling the function, I uninstalled the app and the swipe up to search isn't come back.
