Xiaomi Mi Pad 5
andrewkb
I cannot find as well.
What bugs me more is the Google app icons like Gmail, Drive, Photos are the old ones. o_O
Go Home Screen settings and turn off Gobal Icon Animation
>> Noticed this setting is in phone but not on pad 😑
Crayon Shinchan
0% battery? If so let it charge more before try on it. Make sure use original charger. Last, time send to service center.
yup. manage to charge it and start up. yesterday before i sleep. it was about 95% (turned on). this morning when i wake up. the tablet was turn off and quite hot. after i turn on it was at 22% only. seems very weird.
charging it up again and maybe do a factory reset later to see if it resolve the issue
jhleo1
Something not right..... if you not install some app that run at background, should be battery drains so much till turn off itself. Mostly hardware issue....
Crayon Shinchan
yup. technically everything is still very fresh on default. havent even install any apps. just done the initial basic setup to go the main menu.
Since the tablet is turn off when i wake up, i cant see any battery consumption history.
Now i will charge it up and monitor on day time to see what could be happening.
eS.KuKu
bought my set from SLS on qoo10. confirm it's local set with netflix in HD. no disney+ to try
thunderskain
MIUI gurus,
How to disable the Search function when we swipe up from the bottom of display in MIUI 12.5x? :unsure:
I find it super duper irritating..:poop:
I couldn't find any selection? :unsure:
Don't tell me must adb to remove? :unsure:
I removed by installing this app. After disabling the function, I uninstalled the app and the swipe up to search isn't come back.
I just changed it to app drawer instead of classic and the search is gone.
lovejolin
This is Netflix on my tablet. I don't have Disney plus so can't test.
I am having L1 widevine also. But somehow the video quality seems crappy. Plus ours is a 2k screen.
not sure it if it is my problem hahaha. I feel the video quality feels subpar like SD(although the title format puts it at HD and my settings are all set at high). My old OnePlus 7t feels like HD when watching Netflix. Not gonna compare it with my iPhone 13 Pro(this one different category already haha).
x3nor_S
Cause screen bigger? DPI definitely lower than if u are on smaller screen. I do notice quality is bad at the start when video is loading then after it gets better
lovejolin
Yeah the only reason I can tell myself is probably screen bigger. I still feel the quality is bad after initial buffer like you said hahaha. But it is still a value for money tablet.
kelvinti
Drawer, I see. But I have never liked Drawer! :sleep:
Anyway, I adb shell into it last night but not sure which is the package for that particular "Swipe Up for Google Search"? So, ended up I did not remove anything yet. :sneaky:
lbcben
I see many selling in carousell, with front box view, I don see any EIN sticker, 100% sticker is pasted on the front view, correct?
so if no sticker, but they claim is local set, also not counted?
thunderskain
Just applied the TG. No surprise from Nilkin, the same good coating and premium feel on the screen. Doesn't have too much fingerprint and very smooth on par with he default coating of the actual glass.
Nakedtoes
Got provide template to paste?
eS.KuKu
got mine from SLS, no sticker on the box though
Nakedtoes
Mine pad 5 order 24th sept now then reach... Paste tempered glass and play liaoz.. Shiok.. The sound is pretty good.
