GANGSTERKIA
- Oct 6, 2010
pentax, kodak, OSS.Let's say a 200 budget, which single vision blue filter should I head for? Any brand to recommend.
It really depends on many factors, e.g. prescription changing, tired of current glasses look etc. Most can wear for at least 2-3 yrs.Hello, been wearing a Ray-ban's with basic hoya lens for about 2/3 years when using desktop or watch tv. Mainly due to a faulty right eye but perfect left eye combo. Just wondering, how long does it take for people to change their spectacles? And also if your don't mind, any specs shops to reco around the north east/ central area? Thanks
Both actually. I am really surprised how Lindberg isnt fitting me well since everyone seems to be saying how light and comfortable they are.Hi, additionally just to check, when removing your glasses, do you usually use one hand to remove or both?
Any review on lenskart progressive lens? They are offering their in-house and Tokai Lutina progressive. Anyone tried their in-house progressive? Any review on Tokai progressive lens?
It seems that they are not offering Rodenstock progressive anymore. The salesperson say that they have changed to Tokai progressive.I tried Lenskart Rodenstock progressive and am a satisfied customer. It's probably 90% as good as my Hoya Mystyle lens but costs much lesser.
Hi,Do frame prices of Oakleys differ from store to store? Made my previous pair at a shop near my office but now WFH so would prefer a shop nearer to my home (Jurong) (probably Spectacle Hut) as long as price doesn't differ
Yes, but depending on the lenses you choose, might have to leave the frame down for a few mins to let them trace the shape/size of the frame and lens.Would like to check is it possible to do a lens replacement without leaving the frame at the store?
As I still need the specs to see even though the existing lens have issues
Try Lenskart. You will get 1 + 1 pair within your budget . I am satisfied with my first pair of glassesLet's say a 200 budget, which single vision blue filter should I head for? Any brand to recommend.
Your prescription is very low. Try lenskart progressive lens (one pair of lenses will take care of your dual vision issue).Hi GANGSTERKIA,
Can you please recommend the best lens for >40yr for these 2 uses-cases? No budget in mind.
1) Pure computer/office use
2) General indoor use (watch TV, reading, use phone, tablet, PC etc)
Prescription:
OD +0.5 / CYL -0.50
OS +0.75 / CYL -0.75
Thanks!
Light weight, durable and comfortable pair of frame. Markus t is considered premium and it’s well worth the price.markus t dot mono L1034
Recently I’ve tried on this frame and quite like it, anyone got experience with this brand? It’s quite costly as after adding in my lens it cost more than $1k. Thanks for any information
Hey there, your prescription is rather Low. I would suggest probably office lenses. I am not sure how far is the distance from you and your television.Hi GANGSTERKIA,
Prescription:
OD +0.5 / CYL -0.50
Thanks!
Yes it’s possible but, you have to ensure the new frame size is similar to your current one so the pupillary distance won’t be affected too much. If the difference is high, it will induce prismatic effect(giddy,distortion) when you look through your lenses. Can is can however must manage your expectation if you don’t mind.Hi all. I need some advise, isit possible to use the current lens I'm using and just change the frame, or it will be difficult to do so, my current lens is from zeiss. Wanted to save some money if I can just get the frame instead of changing a whole new set if possible
Thanks for the information. I shall visit some others shop for other design meanwhile. Maybe if can find something similar and price lower it will be ideal.Light weight, durable and comfortable pair of frame. Markus t is considered premium and it’s well worth the price.
