Pocophone F3
KeYoKe
That i agree. hahah
Really hope POCO can go more "stock" for the entire OS.
It will really boost their sales, because besides pixel.. there isn't really any options :o
Yes... Miui is jus a mess. I move to custom rom once they removed multiple schedule DND in miui 12.5 (now, it seems like this can only be set in the DND under digital wellbeing :s22: what a funny change)
Crayon Shinchan
12.5.4 not bad lah. Every UI has it's pros and cons.
And yes it has floating windows.
With 4G data on yesterday. Battery still drain 9% overnight on MIUI 12.5.4.
Generally i think just the network communication eats alot of batt. Already done all the things below, don't think i miss anything out.
on MIUI 12.5.4, debloated, auto update disabled on background for gstore, 120hz RF, AOD Disabled, Battery and performance > Clear all data (Done), wifi assistant disabled, Closed background apps before sleep and clear cache when device is off enabled.
twosix
the battery consumption is crazy one. sometimes 1% consumed overnite, sometimes range up to 10%. and at around 5am, the phone will sort of reset (w/o rebooting) or clear something in the background. my google sheet shortcuts and widgets will reset. need to reboot the phone to get the widgets back but the shortcuts are gone. haha...
ZhuTou!
U have to disable all sync to save more battery
Crayon Shinchan
you mean this page?
Read HWZ Forum Rules!
Nakedtoes
I set auto sync n off... Both setting not much different in battery consumption
Hailgod
mine drains like 5% overnight. wifi,data, sync on.
12.5.2. not planning on updating.
twosix
last nite drop from 70% to 66%: 4%, with wifi, bt and data on. dnd, with bedtime mode and battery saver auto on and off at nite.
