Electric toothbrush
KYLee
How's zemyum sonic? Feel like buying after my 9.90 guardian electric toothbrush died after 6 mths of usage.
standarture
Don't waste with flosser. Not even close to traditional flosser. Maybe only useful for some bits stuck in your teeth. Any simple form of plaque, it can't remove already.
sTiCkY
moi the vibration head a bit discolour after changing head.. :frown:
rust colour.. i normally don't take the head out... jin em0se...
CCCustom
This thread popping back up again reminded me ...
I have a problem ... my last trip to NUH Dental, the dentist said that a hole in my tooth had signs of abrasion from use of electric toothbrush, and asked me to switch back to a regular toothbrush :s22:
I use the Oral B Pro2 2500 with CrossAction heads. Anyone can SIC what would be the softest head possible to use? Or would switching to a sonic toothbrush instead be better? I can’t see myself going back to regular toothbrushes :o
desmond007
Try those 12000 brittles toothbrush...soft yet good cleaning & go easy on receding gum.
King.Koopa
Sian need to top up my oral b head brush. Last time bought 4 for 20$ now become 4 for 29$ up almost 50% 😨
PrincZe
I bought from shopee seller instead. Found one even cheaper than previous bought at lazada. 3 for 14.95. With 10% discount and 15% cash back coins
Can sic link?
Read HWZ Forum Rules!
KPO_SAHM
Anyone got good recommendations for electric toothbrush? Budget 50+
Sent from Samsung SM-G935F using GAGT
I have been using manual toothbrushes. No such issue of tooth decay or stinking gums and. So on...cause I floss them every day + routine dental check up. And I am using kid toothbrush as I feel it clean better. And I bought Elgydium Teaching Plaque Disclosing Toothpaste 50ml. Once a while I will use that. As for my kids they r using that toothpaste. Non of them have oral hygenie problem
Istayatdakota
got any electric tooth brush that uses usb c to recharge? currently everything i have is usb c, even my waterflosser haha. dw use micro usb
