Habrosus
haha... ok... i thought let tpg track ur location.
they should name it "tpg usage tracker".
Not enough space on the homescreen to have so many words. 😅
Don't all telco apps generally show the usage among other things? I hardly open these apps except MyRepublic and ChangiGo these days, the former because I only have 8GB there and Changi because I just like to look at it. 😋
twosix
i dun check the usages. nowadays always at home, rarely use 4G.
xonix
Is TPG current coverage good enough for malls tracetogether app check ins ?
Applying for my mother when she go buy groceries, cannot rely on token liao.
Habrosus
My sibling got this for our parent too. No complaint so far.
keenklee
IMHO.
If enter via underground carpark at Waterway Point, would be subjective.
kazuki666
Hi guys. check with you TPG users. I am a new user to TPG $10 postpaid line. I just received an email from TPG saying this
Your TPG 50GB SIM Only Plan XXXXX is renewed. Your next renewal date is 14-11-2021.
How come postpaid line is considered renewed. Is this the usual email monthly?
Habrosus
AFAIK, yes, and I just ignore them so long as I'm only charged once a month $10 plus the line works as it should.
Long story short, some of these messages are standard copy-paste without any in-depth thoughts.
ichinisan
keenklee
Is it mainly underground reception that is affected? Other areas should be fine?
Short version.
IMHO, other areas should be fine.
Long version.
IMHO. In my testing.
TPG's performance is very much location dependent.
You can have good reception but insufficient bandwidth.
In more dense location, the overall bandwidth is higher.
But once the users start to come in, the share of the bandwidth will be lower.
At that price, actually no harm using it.
andyhtc
Suspended
TPG is pre-paid. You may recall you paid $10 when you first registered.
Hotsnow
Tpg website stated that its "TPG 50GB Prepaid Plan" is a prepaid plan and it support prepaid port in from others telco.
Can this be later upgraded to postpaid? Then for subsequent port out to other telco.(As M1 prepaid to postpaid need pay >$45)
ichinisan
Short version.
Long version.
That is true. The price is the attractive point. Gain some and lose some.
