Burningbone
- Oct 6, 2010
Is it katanpang leaf water? Most lfs put it with the fish etc.Why the shrimp water from 328 yellowish? It has faint sweet salty smell from the water
Is there heavy metal contain in the water like copper? Fish won't die but shrimp will if there is. Generally those red shrimp is hardy, I use them to cycled my water on first dayGood for you.
My red shrimps kept dying till I give up. Bought many times from different places and same thing happened.
Now switch to tetra and they are doing well in the same tank.
Couldn't figure out why the shrimps died.
your tank size is OK unless you don't fill it up to the max.
what's inside the tank?
How much water you change each time and what frequency?
trying changing more like 30%.Change weekly 15% each time.
You need to drip acclimate them for 6 hoursGood for you.
Feed black tip sharks with Oscar.
get this, a small pump, hose and a styrofoam box.Recently very hot and my tank temp going at 31-32c at night. Don't even know what is the temp @ day light when I am out at work. Anybody got diy to make the tank cooler? I use mini fan and it drop less than 1c.
Wa sound good! But How does this work to cool the tank? Or what is the set up need to do?get this, a small pump, hose and a styrofoam box.
can diy a chiller liao.
i explain this before in this thread.Wa sound good! But How does this work to cool the tank? Or what is the set up need to do?
http://www.tantora-intl.com/index.php?lay=show&ac=article&Id=539724902&Ntype=8Is it katanpang leaf water? Most lfs put it with the fish etc.
Ohhh! Thanks for the clarification!No. You misunderstood him.
Step 1. Have a box like this filled with ICE and maybe some salt to further lower the temp. Make sure it is well insulated to prevent Heat from entering. Connect rubber hose to the inlet and outlet.
Step 2. Connect the Hose outlet to another coil like this and put this into the Aquarium.
Step 3. Connect other end of the coil to a hose and connect this hose to a water pump inlet.
Step 4. Connect pump outlet to box inlet with another hose.
Step 5. Use the thermostat to control the ON/OFF of the water pump.
Personally i think just use a stronger fan will do. These few days outside temperature is 34 degree C. My house is 30 degree C. My fish tank with a USB fan blowing is 27/28 degree C. Quite comfortable temp for shrimps.
My current shrimp tank temperature.
not air pump.Ohhh! Thanks for the clarification!
this is a wood shrimp?This is one of my favorite shrimp!
Located at my main tank with the fishes.
