Xiaomi Mi Pad 5
bryant_16
For media consumption. Non Pro is more than good enough.
The SD860 (aka SD855+) and GPU Adreno 640 are powerful enough already for Netflix, YouTube, MeWatch and all others online and offline media streaming and game plays.
Anyway, Pro version doesn't have global set yet or it may not come at all.
Thanks sir for your help!
MoneyHoney
you go xiaomi retail store eg. Vivo, Jem. they ONLY selling 256Gb version
hi hi.. i’m looking for the 256gb version…
does anyone know if the retail store has ample stock available?? how much are they selling for the 256gb??
Crayon Shinchan
It has! By default, all apps notifications are without vibrator!
You need to go to the Notification setting and enable vibration for apps notifications!
:cool:
my mipad5 totally no vibration or heptic feedback though. even download this test app. it doesn't have vibration
when I go to my device setting like nothing about vibration as well.
even on gboard setting the heptic feedback setting is not there
Read HWZ Forum Rules!
Parka
Am thinking of selling away my Samsung tab s7 for this mipad 5. Any suggestions?
More of a media consumption user here.
Tab S7 is the better tablet.
Better latency, s pen included, more RAM, SD card storage, Samsung Dex.
If you sell, it's almost like buying the same tablet but with less features.-_-"
Nakedtoes
Why need vibration for tablet... Dun put in pocket... It's same like mini laptop. U dun see laptop having vibration right.?
thunderskain
Some games feels better with haptics.. having some response when pushing button is nice. That being said I don't think Xiaomi pad 5 has haptics.
Crayon Shinchan
not say really really need it. just curious does it have it.
After some research i think MiPad5 does not have vibraition/haptic feedback as it does not have any vibration motor
1-wind
Anyone encounter some device error prompt after streaming Netflix for a while, then Netflix crashed?
Then I restarted Netflix and it was unable to go to HD. Downloaded DRM Info from the Play Store and it shows as Widevine L3...
MoneyHoney
does the mipad 5 supports app like netflix and disney+ in the google play app store?
strangely my mi max3 google play store doesnt have both apps available... not sure if this is a limitation on xiaomi?
jhleo1
All Xiaomi pad 5 series are Widevine L1 ready.
jhleo1
I know, just sharing that I encounter errors for Netflix... I rebooted then regained the L1 status.
Actually you are not the one. I just saw pple faced it today too in Facebook. L1 turn to L3 in Netflix.
andrewkb
Just received my smart flip cover. However the flip to wake is not working. I've enabled the setting, and even moved a magnet around the screen (I assume it's magnet triggered). Anyone know where is the sensor located?
Nakedtoes
I know some case dun support.. Mine rotating flip case.. Is if u orientate the pad 5 straight then can trigger by the case..if u put upside down.. Cannot work..
andrewkb
Specifically bought from seller whom indicated smart wake/sleep. Just reboot, test rotate etc. All not working leh...
Update: After much trial and error, I noticed they've placed the magnet opposite way. If i flip the cover the other way round (front cover facing down) , it works 😅. Raised a dispute on the item now.
