Redmi Note 11 series
Krabs.
SINGAPORE launch date 11 feb 2022
all are amoled screen , no more LCD
6.43" screen , 90hz , 33watt charging , snapdragon 680 cpu
https://www.gsmarena.com/xiaomi_redmi_note_11-11336.php
same as above but cpu mediatek G96 & 108mp camera
https://www.gsmarena.com/xiaomi_redmi_note_11s-11335.php
6.67" screen , 120hz , 67watt charging , mediatek G96 cpu , 108mp camera
https://www.gsmarena.com/xiaomi_redmi_note_11_pro-11334.php
same as above , snapdragon 695 cpu with 5G
https://www.gsmarena.com/xiaomi_redmi_note_11_pro_5g-11333.php
all are different from the rmn11 pro pro+ china version with mediatek dimensity 810 920 cpu
brought over same standard are flat sides , Z-axis vibration motor , stereo speakers
amazingone
announcement date 28 October 7pm
shipping date nov 1 in china
source : https://www.gizmochina.com/2021/10/...es-launch-date-revealed-heres-what-to-expect/
The frame design is new for Redmi Note, reminiscent to iPhone 12/13 design.
8-lane
The placement and the design of the camera setup is very similar to that of Redmi 10 (below). The iPhon-esque frame of the Redmi Note 11 means its back is totally flat as opposed to that of Redmi 10's curved back. For me personally, I prefer the back to be curved.... I find it nicer aesthetically and it makes the phone more comfortable to hold in the hand.
amazingone
lots of conflicting rumor leakers around on weibo
if the lowest vanilla kena cut too much features like ufs3.1 storage and reduce ram to 4gb while the price is too close to the middle Pro ...... then it doesn't make sense
I guess they want people to buy the Pro models instead, thus they cut the specs on the vanilla model to make the Pro models more attractive.
amazingone
i thought the leak say note 11 is 120hz LCD?
Already confirmed by Redmi that the whole Redmi Note 11 Series will be using AMOLED.
Redmi GM Lu Weibing advised those who wants LCD to consider the Redmi Note 10 Series (China), as Note 11 Series will be using AMOLED :o
Hailgod
oh then i guess note 11 is also samsung amoled, not boe/other chinese maker.
amazingone
can the difference in amoled manufacturer be felt by eyeball :s11: and longevity ?
Usually not very noticeable unless your eyes are sensitive to the pixel layout.
Samsung AMOLED uses Pentile sub-pixel layout, which is a Samsung exclusive. Other display makers have their own sub-pixel layout.
Tenpai
still on mediatek = bad train?
is amd still bad oso? hahahha
I think MTK has improved a lot. My nephew using Samsung with MTK Helio G80 with One UI 3.1 but it is surprisingly fast and smooth. IMO, SD > MTK > Exynos
Ctrl_Alt_Del
helio generally way hotter than qualcomn. Dimensity is better but still slightly hotter than qualcomn.
ZhuTou!
Dimensity is not bad la
Dun keep sticking with the old gen mtk mindset
Like old ppl like that, mindset never change
Machiam the war btw intel vs amd
Tech will upgrade and improve over time
Altho there are not much redmi 10x user here but most will tell u their phone is ok and satisfied with their phone
I use 1+yr liao never give me problem, not even hot like the old gen mtk
Last time all siam china product
Now all use china product
Things will change
