Xiaomi Mi Pad 5
kelvinti
Hi bro, can show your EQ settings? I find tht my unit sound not as loud as i liked
Well! It makes no difference as this tablet has 4 speakers but well....the volume of the 4 speakers combined are not that loud as we would have expected from a tablet! :whistle:
Isaac2107
Yeah loo. what todo right? But at least now with your eq settings can be abit more boomy i suppose
kelvinti
nzxtme
Affirmative!
. Just double check any paper proof of local warranty from the seller.
You can always check the authentication and certain details of Xiaomi mobile products on the spot here too.
Product Authentication
Verify your phone purchase
favicon.ico
www.mi.com
Yay! Thank you so much for the info & link :)
Read HWZ Forum Rules!
kelvinti
Can i ask what on screen keyboard are you guys using? Any good recommendations?
Gboard is good enough! :whistle: . Samsung keyboard is pretty neat too! :)
Personally, I like Swiftkey and I use English and Chinese handwriting keyboards! :whistle:
znltan
previously saw someone mentioned about removing the swipe up Google search
able to share how to disable it? seems like not in the home screen setting.
I removed by installing this app. After disabling the function, I uninstalled the app and the swipe up to search isn't come back.
Refer to these above posts.
jhleo1
Instead of use ADB which I long time not try and scare accidentally remove the stock app & create problem subsequently, will use those "MIUI Hidden Settings" app to disable the app work?
sonnawabit
Anyone getting a problem on global version, netflix will kick you out halfway throughout watching a show and when you re-login, it will revert to widevine L3 and standard definition only (not Full HD as before)
Really annoying issue that I thought was solved for global version but guess not
