wongminmin
- Nov 10, 2014
i can buy universal controller. is it better/wise to get kdk instead of fanco?durable but not for the remote. You have 50-50 chance of it faulting.
Kdk lasted forever without an issue so far for me. However depends on the model too. Kdk also quite ugly looking if design is a concern...i can buy universal controller. is it better/wise to get kdk instead of fanco?
u can ask shopee aveavenue , they are very professional and explain every thing in details.The more durable brand is fanco and KDK?
Looking for ceiling fans with lights.
depends which model you are referring. In terms of Branding, Crestar position slightly more premium than Fanco. In terms of after sales service, Crestar is much faster to arrange. By best selling products from the brand, Crestar is valueair and fanco is Bstar. Value for DC type of fan will be bstar at $189 which is the cheapest in the market with remote and led light. Wind generated is bstar fan much stronger. Noise generated is valueair is much more silent compare to bstar. Led light brightness is valueair brighter at 20w and bstar is 18w. Hope the above clarifies your concern. Thank you![]()
u got install speed regulator switch for fanco?Kdk lasted forever without an issue so far for me. However depends on the model too. Kdk also quite ugly looking if design is a concern...
no. i using smart switch to turn it on and RF hub to toggle the speed of the fan - both controlled via my phone/app.u got install speed regulator switch for fanco?
Went and experienced Bestar Vino at Serangoon Central area... finally a place without aircon so I can know if it's due to the fan itself. Pricing is okay, $268 - $288.
Anybody using Bestar Vino? seems like its quite new
HiPO ECO Fan. Saw the reviews here. Damn scare to get. 2-3 years will break down (Driver issue).
many places, ubi, hostsystems etc.Hi
where can see reviews on Po ECO fan ?
Am interested to get one
got mine too 54". so far so good.Just installed PO Fan Gust
so far so good
46" version for my room
The wind better than my old Crestar 5 blades fan
Have used KDK, Fanco, Crestar
KDK uses IR remote. The remote controller spoil easily but can get from Laz or Shopee easily for $30~$50
Those fans use RF controllers, average 2~3 yrs will spoil. Need to get the service center to send technician to change. Cost of RF remote + Receiver + technician = over $100
Mine black in colourThe PO Fan WiFi version comes with the ugly White Remote Controller
Sian
Which Gust blade design number you get?Just installed PO Fan Gust
so far so good
one thing i really like about efenz fan is, the remote control works even if it is behind a wall... u dun have to point at it.
