Redmi Note 11 series
8-lane
Nice curved back but out of the 5 "lenses" at the back... only 2 are cams... btw this is the Redmi Note 11...
Shutterbox
i did a compare in gsmarena between RMN11 Pro and Pro +
apart from Pro+ 3g lighter than Pro, and Pro having a bigger battery capacity than pro+, no other differnces found!
ZrE0_Cha0s
still prefer to have a delicated sd try though.....but i find that note 11 pro might have design using this kind of sim slot will be most likely the either the battery part or maybe the changes to its design board . hopefully got someone do a teardown on the phone :p
Tenpai
chip shortage so jialat until no Snapdragon for Note series?
Hailgod
i think mediatek is just better value for money in the mid range. it make sense for xiaomi, especially redmi to be using them more.
Hailgod
I know MTK is more value for lower-end to midrange, just missing the "good" days of Redmi when most have SD
the only sd 7xx chip that performs better and has more features than the mtk 920 is sd 778/sd780.
its not like they are choosing mtk just to save money. they are providing a better SOC likely for less money.
atomz_87
If want to have UK 3pin plug charger and also Google play, need to get the global version?
