Hi gurus, bought a resale and have a few qns before I stock up during 11.11.
Context to make qn answering easier:
- Zigbee Hub:
- Either Samsung ST or Aqara M2, don't really wanna mess around too much w/ HA
- If using Aqara, prefer not to use China region due lag
- Integration w Google Home nice, but not necessary
- Smart switches for lights - previous owner has a lot of track lights, may not be easy to get smart bulbs for those
- Smart blinds - prefer to use a smart winder since I have existing dumb blinds
- Smart lock - if possible I want hands free opening (eg facial recognition or presence detection from phone)
Questions
- Switches: If using Aqara M2 international version, can the D1 China switches still work with it, without changing to China region? I know there'll be no integration w Google Home.
- Switches: If using ST, how stable is the DH for the non-neutral Aqara switches? Anyone had exp using that?
- Switches: If using ST and I don't get Aqara, any other recommendations for switches?
- Smart blinds: The Aqara E1 Roller Driver seems like the best fit for me, but international version everywhere like got no stock sia. Anyone know if China ver work outside China?
- Smart blinds: If Aqara is no go I might go with Ikea FYRTUR. Anyone with exp on how well it works with ST or Google Home? Definitely don't wanna buy the Ikea hub just coz of the blinds...
- Smart lock: I know some of the newer Samsung locks have ST integration based on Hanman brochure - can they be auto-unlocked based on routines I set in ST, or u die die need to interact with some app?
- Smart lock: If not Samsung I might go with August coz they have geofencing etc, but seems like without the August connect its kinda ****. Anyone got exp?
Sorry for so many qns and thx!!
Not sure whether I should answer this, you probably watched my videos already.
1. According to Aqara - 'In theory, only the oversea products (regardless they are global/US/EU/UK version) are configured be to connected with the oversea servers. But in real world, users sometime might be able to add the Chinese version products to the oversea servers, and that's mainly because these Chinese products share the same model value and hence the same configuration with the oversea products. Of course this won't be the case for all Chinese products, and that's reason we highly recommend global users to purchase "right" Aqara products that are designed to be sold and used in the local region.'
2. Yup I am using ST with Aqara non neutral switches and they are working perfectly fine for me. But I can only say for those switches that I am using. Some people say 3gang switches will have problems but some of my viewers comment it works fine using the DH I am using
3. I never use other brands before but can explore Shelly/Sonoff
4. No idea
5. Works perfectly with ST. If you don't intend to get the ikea hub then your question to work with Google home is NA.
6. You can probably check with Hanman directly
7. No experience with August locks. As long as ST has geofencing, it doesn't matter I guess.
