Pocophone F3
SecretAgent
is this F3 true IP53 rated?
I jog in the rain.. so good to be waterproof for me.
Currently using x3pro... bloody piece of brick. Overall serve me well except I really need something lighter and AOD...
if it's just $429 during 1111...then I think I'll get one.
wwh5210
then what's water resistant?:s11:
  1. (or X - see section below): No protection.
  2. Protection against vertically falling droplets, such as condensation. ensuring that no damage or interrupted functioning of components will be incurred when an item is upright.
  3. Protection against water droplets deflected up to 15° from vertical
  4. Protected against spray up to 60° from vertical.
  5. Protected against water splashes from all directions. Tested for a minimum of 10 minutes with an oscillating spray (limited ingress permitted with no harmful effects).
  6. Protection against low-pressure jets (6.3 mm) of directed water from any angle (limited ingress permitted with no harmful effects).
  7. Protection against direct high pressure jets.
  8. Protection against full immersion for up to 30 minutes at depths between 15 cm and 1 metre (limited ingress permitted with no harmful effects).
  9. Protection against extended immersion under higher pressure (i.e. greater depths). Precise parameters of this test will be set and advertised by the manufacturer and may include additional factors such as temperature fluctuations and flow rates, depending on equipment type.
twosix
there is also this much gcam can achieve though
the video recording on gcam itself aint that smooth also. random crashes happening. but not complaining as this phone is only 400 bucks :s13:
this phone dun have ois, so taking video i can accept the quality. but taking photos using gcam produces better results than stock camera app. weird.. haha.
KeYoKe
photos is better. Yes i know there is no OIS. but what i mean is my gcam when taking videos, sometimes randomly crash. not sure why though :s13:
Zenosyne
Where to download gcam? can share the link? thank you :)
dreamz13
For me good photography is good to have, but my concern is more of the lack of dedicated SD card slot and 3.5mm jack (though I am mainly using bluetooth earphone). Just curious if you guys find the lack of SD card slot and phonejack a hassle after using?
By the way, the local set F3 (5G 8GB+256GB), it does have NFC and infrared (able to control tv) correct? The 11-11 $429 is really very very tempting good chance for me to upgrade from my current F1...
I just notice RMN10P just went out of stock both on shopee and Lazada. Not sure if it was intentional or just "close" for 11-11
I don't have use for SD card, and since I'm using bluetooth headphones, so the jack is redundant to me.
Guojing88
Anyone knows how to get Tracetogether app to work with bluetooth in Poco f3?
When I put the phone near the bluetooth scanner, it does not work. I need to use camera to scan the QR code.
What settings do I need to change on my f3?
