[Recommend] Good Mechanical Keyboard
ragnarok95
Senior Moderator
Senior Moderator
i bought my Anne Pro 2 from lazada Zheyuan digital goods. Shipment take around 2 weeks plus. I choose gateron yellow switches. Currently i have both this and Filco minila with cherry red switches. The gateron yellow is smoother for me over the cherry red.
poooooo
Replaced keychron k2v2 crap keycaps with some china generic cheap (15 after vouchers) PBT keycaps. Used only less than a year the stock keycaps on keychron start to peel already...
hellomeister
any recommendations to get individual keycaps with the ridge/bumps only e.g. the bumps on keys like F, J, numpad 5. can be blank in black/grey/white, oem shape.
using k4v2, quite annoying to look down at kb to find arrow keys and delete key. I'm more function over aesthetics.
Phen8210
I feel that outemu switches, those non high-end ones are kinda crap.. like the crappiest of all switches.. is it just me?
deathman91
I've got a Filco Majestouch 2, at times, some of the keys are not registering upon click. Is it due to it being dirty which can be fixed by cleaning it? If so any recommendations of a cleaning kit?
trenzterra
Can I check if I want to buy a Bluetooth keyboard from Taobao, I still have to use my own courier? If I opt for Taobao's own courier, it will fail due to battery?
cesc88
Hi peeps! 1 of my LED lights on my Ducky One 2 keyboard died on me. I purchased the keyboard less than 1.5 years ago. Is this normal? Quite a pity; I do expect better quality from a Ducky keyboard
stylechap
You can try to get it replaced by those with hot air solder service
No guarantee that you can get the same brand same tone led around though
cesc88
Thanks! But is this common, as in LED failing after less than 1.5 years of use? How much would it cost?
stylechap
Not sure what kind of led yours is using
But definitely not very expensive
Just your luck maybe🤷‍♀️
Some brands rgb lighting came haywire out of factory also
carmelmore
Which Bluetooth keyboard you plan to get or still going for the Niz plum?
spectrearc
Glorious shouldn't you be buying the keeb barebones so u can build yourself?
Anw, for BT keyboard I bought a Shurikey Hanzo, haven't tested yet but hopefully it works properly.
marc2002
I dunno how to build haha. So this one, i prob have to read the manual also -_-!
KeYoKe
hey guys, my filco majestouch 2 is registering multiple inputs upon single press on certain letters, so am looking to replace.
am looking at rk61 or anne pro 2. anyone whom have used both can give some feedbacks on both?
