Real International speed tests
What ISP are you testing on?
  • Total voters
    64
rubicon
It could be your RT-AC68U also play a part in the speedtest results. If you can use a PC connected to the router. My results shows my mini PC J4105 > Raspberry Pi 400 > Asus RT-AX82U.
The RT-AX82U CPU will still be much faster than the RT-AC68U.
I used top to monitor the CPU load. Doesn't seem saturated.
As a baseline, I ran speedtest on the local ViewQwest server.
results around 250 Mbps +/-
Code:
admin@RT-AC68U-5B78:/tmp/home/root# /usr/sbin/ookla -c http://www.speedtest.net/api/embed/vz0azjarf5enop8a/config --interface=vlan2 --server-id=2054 --progress=no --format=human-readable
     Server: ViewQwest - Singapore (id = 2054)
        ISP: Viewqwest
    Latency:     1.45 ms   (0.36 ms jitter)
   Download:   264.62 Mbps (data used: 308.0 MB)
     Upload:   195.80 Mbps (data used: 237.0 MB)
Packet Loss:     0.0%
admin@RT-AC68U-5B78:/tmp/home/root# /usr/sbin/ookla -c http://www.speedtest.net/api/embed/vz0azjarf5enop8a/config --interface=vlan2 --server-id=16974 --progress=no --format=human-readable
     Server: Spectrum - Los Angeles, CA (id = 16974)
        ISP: Viewqwest
    Latency:   181.78 ms   (0.44 ms jitter)
   Download:    93.24 Mbps (data used: 102.3 MB)
     Upload:    99.52 Mbps (data used: 95.0 MB)
Packet Loss:     0.0%
Question: if I'm on 1 Gbps plan, does it mean that each port on the ONT is limited to 250 Mbps?
It is not about CPU usage. The whole system is slow and that may limit the speedtest result.
If the baseline speed is only 250Mbps, something is wrong already. You may want to use a laptop directly connected to the Viewquest ONT to see the speed is normal or not. That should give you around 900Mbps or higher.
If that is not the case, contact Viewquest for support.
If that is the case, it is either you have some QoS turned on on the RT-AC68U or the speedtest client in the RT-AC68U can not be used for your test due to the slow system.
The other thing is that the command line output mentioned interface is vlan2 and you may want to check that as well.
All in all, use a laptop or desktop to test first.
rubicon
Thank you.
I'll try to get a laptop connected directly to the ONT (not very convenient as many laptops no longer have ethernet ports).
I've filed a support request with ViewQwest, hopefully they can get a technician down to take a look.
firesong
Deluxe Member
Thank you.
I have the Ugreen USB 3.0 ethernet adaptor. I believe @xiaofan uses that too, and/or the USB-C variant.
The USB2.0 adaptors won't work since there's a theoretical 480Mbps throughput max on USB2. It'll work for basic connectivity, but not for testing max speed.
@xiaofan
Yes I have one Ugreen USB 3 to gigabit Ethernet adapter. I used that one for SpeedTest as my two Acer Swift 3 laptops do not have Ethernet ports.
Now that adapter is uses as WAN port for my Raspberry Pi 400 running OpenWRT 21.02 as a router (replaced Intel J4105 mini PC running pfSense as I use the J4105 mini PC as a Linux server now).
However, I bought three UGreen USB 3 to 2.5G Ethernet adapters (two USB 3 and one USB Type C) so I am using them as the adapter for speedtest. Kind of overkill but they are meant for my 2.5G home network experiment but I have not really proceed with the experiment in the end -- not feeling the need to get an NAS yet and choose to pay Google (and probably Apple later) for the cloud storage.
firesong
Deluxe Member
Even though I have a NAS, I can't use it for iPhone/Android device backups. -_-
It's one way to force us to pay for storage upgrades. So I pay Apple and I have MS 365 (partly cos Office, but actually because of versioning protection for my documents).
rubicon
just wondering what's the international speed for singtel fiber at peak period (10pm)?
Viewqwest is super slow.
firesong
Deluxe Member
wow looks like ViewQwest really sucks compared to Singtel (looking at LA Comcast).
Will try to run a test later. Do you have the server ID? I can't get LA Comcast on my options.
Have put together a simple shell script that just sequentially tests various servers.
Code:
#spdt.sh
#!/bin/bash
# Singtel
speedtest -s 25960
# ViewQuest SG
speedtest -s 2054
# PT FirstMedia - Singapore
speedtest -s 7556
# Comcast - Sacramento, CA
speedtest -s 9436
# Spectrum - Los Angeles, CA
speedtest -s 16974
# University of Texas, Austin - Austin, TX
speedtest -s 16089
# Optus - Melbourne, AU
speedtest -s 30932
# Misaka Network Inc - Tokyo, JP
speedtest -s 44988
# SIMPLYCONNECT - Dar es Salaam
speedtest -s 13902
# Bell Mobility - Vancouver, BC
speedtest -s 17402
# Telstra International - HK
speedtest -s 44340
rubicon
16974. Apologies it's "LA Spectrum". thank you.
one point I was wrong about on the command line binary. It does seem to use multiple connections after all (using netstat).
firesong
Deluxe Member
ServerLatencyDownloadUploadLoss
Singtel - Singapore (id = 25960)2.23 ms (0.11 ms jitter)949.42 Mbps (data used: 954.1 MB )946.35 Mbps (data used: 1.1 GB ) 0.0%
ViewQwest - Singapore (id = 2054)2.56 ms (0.09 ms jitter)940.87 Mbps (data used: 913.9 MB ) 937.66 Mbps (data used: 1.1 GB )0.0%
PT FirstMedia - Singapore (id = 7556)1.79 ms (0.11 ms jitter)943.65 Mbps (data used: 458.8 MB )935.92 Mbps (data used: 1.2 GB )0.0%
Comcast - Sacramento, CA (id = 9436)183.62 ms (0.16 ms jitter)888.23 Mbps (data used: 1.4 GB )143.33 Mbps (data used: 196.5 MB )0.0%
Spectrum - Los Angeles, CA (id = 16974)186.75 ms (0.19 ms jitter)930.08 Mbps (data used: 1.4 GB )151.29 Mbps (data used: 262.8 MB )0.0%
University of Texas, Austin - Austin, TX (id = 16089)233.51 ms (0.13 ms jitter)184.03 Mbps (data used: 265.4 MB )28.07 Mbps (data used: 42.9 MB )0.0%
Optus - Melbourne (id = 30932)107.39 ms (0.06 ms jitter)937.89 Mbps (data used: 1.4 GB )179.91 Mbps (data used: 239.9 MB )0.0%
Misaka Network, Inc. - Tokyo (id = 44988)77.70 ms (0.16 ms jitter)650.75 Mbps (data used: 891.4 MB )235.86 Mbps (data used: 257.0 MB )0.0%
SIMPLYCONNECT - Dar es Salaam (id = 13902)479.04 ms (7.04 ms jitter)1.73 Mbps (data used: 2.8 MB )15.98 Mbps (data used: 26.9 MB )0.3%
Celcom Axiata - Kuala Lumpur (id = 4956)228.08 ms (0.17 ms jitter)656.44 Mbps (data used: 1.0 GB )119.44 Mbps (data used: 127.2 MB )0.0%
Bell Mobility - Vancouver, BC (id = 17402)259.97 ms (4.21 ms jitter)865.50 Mbps (data used: 1.2 GB )112.60 Mbps (data used: 130.9 MB )0.0%
Telstra International - Hong Kong (id = 44340)34.24 ms (0.86 ms jitter)948.45 Mbps (data used: 1.1 GB )465.70 Mbps (data used: 677.6 MB )0.0%
Just did a test run and copy/pasted the info.
firesong
Deluxe Member
which Singtel plan is this?
Maybe I should just get a second fiber line
Standard 1Gbps. I don't believe in subscribing to any higher tier plans for now. In fact, I still think 500Mbps is more than adequate for most home use cases.
Singtel - Singapore (id = 25960)2.23 ms (0.11 ms jitter)949.42 Mbps (data used: 954.1 MB )946.35 Mbps (data used: 1.1 GB )0.0%
Your results seem to be very good for SIngtel 1Gbps plan.
My results are much lower (tested using Raspberry Pi 400 runing OpenWRT 21.02.01, ignore the local upload speed because I have a SQM-QoS rule to limit to 500Mbps).
Test is not done in the optimal time though -- Singtel TV is on, family members are using Youtube and other apps.
Code:
   Speedtest by Ookla
     Server: Singtel - Singapore (id = 25960)
        ISP: Singtel Fiber
    Latency:     1.34 ms   (0.08 ms jitter)
   Download:   938.06 Mbps (data used: 446.9 MB )
     Upload:   482.12 Mbps (data used: 531.5 MB )
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/37c75a5f-5943-4a62-81d5-49e9b4673e3f
   Speedtest by Ookla
        ISP: Singtel Fiber
    Latency:     2.65 ms   (0.06 ms jitter)
   Download:   906.93 Mbps (data used: 845.8 MB )
     Upload:   478.14 Mbps (data used: 532.0 MB )
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/fb7efec4-bc82-4d71-beac-43f50be572b5
   Speedtest by Ookla
     Server: PT FirstMedia - Singapore (id = 7556)
        ISP: Singtel Fiber
    Latency:     2.21 ms   (0.09 ms jitter)
   Download:   911.44 Mbps (data used: 434.3 MB )
     Upload:   478.17 Mbps (data used: 532.1 MB )
Packet Loss: Not available.
 Result URL: https://www.speedtest.net/result/c/7277690d-f6c9-40fc-aba0-f521fd50354e
   Speedtest by Ookla
     Server: Comcast - Sacramento, CA (id = 9436)
        ISP: Singtel Fiber
    Latency:   174.10 ms   (0.10 ms jitter)
   Download:   104.22 Mbps (data used: 147.2 MB )
     Upload:   320.85 Mbps (data used: 552.7 MB )
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/ff6ee2a7-660d-4bb4-8724-c23412dc2e59
   Speedtest by Ookla
        ISP: Singtel Fiber
    Latency:   175.90 ms   (0.05 ms jitter)
   Download:   123.30 Mbps (data used: 183.0 MB )
     Upload:   445.36 Mbps (data used: 747.2 MB )
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/ca08fc39-00e9-4040-9284-508b591380be
   Speedtest by Ookla
     Server: University of Texas, Austin - Austin, TX (id = 16089)
        ISP: Singtel Fiber
    Latency:   238.09 ms   (0.07 ms jitter)
   Download:   363.12 Mbps (data used: 578.3 MB )
     Upload:   151.17 Mbps (data used: 251.6 MB )
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/990ecfca-5277-4c46-8f7f-100182d3771b
   Speedtest by Ookla
     Server: Optus - Melbourne (id = 30932)
        ISP: Singtel Fiber
    Latency:   108.91 ms   (0.10 ms jitter)
   Download:   731.01 Mbps (data used: 1.0 GB )
     Upload:   474.88 Mbps (data used: 744.5 MB )
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/3e2d8273-2567-4b51-aaaa-67335ad6fa2b
   Speedtest by Ookla
     Server: Misaka Network, Inc. - Tokyo (id = 44988)
        ISP: Singtel Fiber
    Latency:    85.41 ms   (0.10 ms jitter)
   Download:   507.30 Mbps (data used: 847.0 MB )
     Upload:   477.11 Mbps (data used: 615.9 MB )
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/0b9858e6-6c14-4a92-9bec-659f208b70e9
   Speedtest by Ookla
     Server: SIMPLYCONNECT - Dar es Salaam (id = 13902)
        ISP: Singtel Fiber
    Latency:   521.68 ms   (0.25 ms jitter)
   Download:     3.03 Mbps (data used: 4.4 MB )
     Upload:     0.90 Mbps (data used: 1.5 MB )
Packet Loss:     5.7%
 Result URL: https://www.speedtest.net/result/c/3ef543f0-a003-43a1-89ef-230c91c24e8f
   Speedtest by Ookla
     Server: Bell Mobility - Vancouver, BC (id = 17402)
        ISP: Singtel Fiber
    Latency:   339.37 ms   (0.09 ms jitter)
   Download:    55.42 Mbps (data used: 69.9 MB )
     Upload:     1.57 Mbps (data used: 3.2 MB )
Packet Loss:     4.2%
 Result URL: https://www.speedtest.net/result/c/13d1a6cd-cdd9-42cd-ab5c-90f9ea5e48ac
   Speedtest by Ookla
     Server: Telstra International - Hong Kong (id = 44340)
        ISP: Singtel Fiber
    Latency:    33.68 ms   (0.04 ms jitter)
   Download:   445.37 Mbps (data used: 647.6 MB )
     Upload:   477.92 Mbps (data used: 578.0 MB )
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/479cdb01-89c4-429c-b034-6723e61c62bb
Using a mini J4105 PC running Ubuntu 21.10 and it is connected to Asus RT-AX82U router. The speed is better now. So I guess the Raspberry Pi 400 still has some limitation and I am using a Ugreen USB 3 to Gigabit Ethernet adapter as the WAN port.
Test is done with SIngtel TV off but with kids are using Youtube.
Code:
myusername@ubuntu64:~/build/speedtest$ ./spdt.sh
   Speedtest by Ookla
        ISP: Singtel Fiber
    Latency:     1.79 ms   (0.25 ms jitter)
   Download:   940.33 Mbps (data used: 448.3 MB)
     Upload:   946.09 Mbps (data used: 1.1 GB)
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/92b07a02-347c-4897-b589-906ed09dcba3
   Speedtest by Ookla
        ISP: Singtel Fiber
    Latency:     2.53 ms   (0.09 ms jitter)
   Download:   896.52 Mbps (data used: 608.3 MB)
     Upload:   936.74 Mbps (data used: 1.2 GB)
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/ea3bd66f-fcfb-41ff-9572-df0c7f8f8326
   Speedtest by Ookla
        ISP: Singtel Fiber
    Latency:     2.09 ms   (0.14 ms jitter)
   Download:   908.52 Mbps (data used: 408.9 MB)
     Upload:   930.64 Mbps (data used: 1.0 GB)
 Result URL: https://www.speedtest.net/result/c/d385e57c-da6d-4ee0-aa0a-afaff9363cd2
   Speedtest by Ookla
        ISP: Singtel Fiber
    Latency:   202.41 ms   (0.17 ms jitter)
   Download:   347.75 Mbps (data used: 523.0 MB)
     Upload:   310.26 Mbps (data used: 520.7 MB)
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/3cb40f74-07ba-422f-a13f-6a0d08c972b7
   Speedtest by Ookla
        ISP: Singtel Fiber
    Latency:   183.66 ms   (0.13 ms jitter)
   Download:   323.27 Mbps (data used: 509.5 MB)
     Upload:   329.06 Mbps (data used: 442.4 MB)
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/0385da92-7cb3-4522-901f-656578026b22
   Speedtest by Ookla
        ISP: Singtel Fiber
    Latency:   252.01 ms   (0.27 ms jitter)
   Download:   125.94 Mbps (data used: 190.2 MB)
     Upload:   145.54 Mbps (data used: 240.4 MB)
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/3ef9b381-f9c9-4d19-8ad1-1a2798c94e08
   Speedtest by Ookla
        ISP: Singtel Fiber
    Latency:   109.51 ms   (0.17 ms jitter)
   Download:   806.31 Mbps (data used: 1.3 GB)
     Upload:   439.99 Mbps (data used: 676.6 MB)
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/682e24a8-1257-4943-94b5-46fc236654f1
   Speedtest by Ookla
        ISP: Singtel Fiber
    Latency:    80.01 ms   (0.19 ms jitter)
   Download:   563.26 Mbps (data used: 659.6 MB)
     Upload:   837.61 Mbps (data used: 1.3 GB)
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/9d819b97-a863-43a9-b95b-a9456c4a5acf
   Speedtest by Ookla
        ISP: Singtel Fiber
    Latency:   431.21 ms   (2.06 ms jitter)
   Download:     4.23 Mbps (data used: 4.9 MB)
     Upload:    24.62 Mbps (data used: 41.2 MB)
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/d5605dc6-3bd2-4f2b-b5ab-19357fa1b6c1
   Speedtest by Ookla
        ISP: Singtel Fiber
    Latency:   306.65 ms   (2.91 ms jitter)
   Download:   335.76 Mbps (data used: 431.2 MB)
     Upload:    83.97 Mbps (data used: 138.9 MB)
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/f25bbf05-159f-40b6-b27d-a4af8ebdfe5e
   Speedtest by Ookla
        ISP: Singtel Fiber
    Latency:    34.85 ms   (0.11 ms jitter)
   Download:   606.16 Mbps (data used: 946.8 MB)
     Upload:   931.83 Mbps (data used: 1.2 GB)
Packet Loss:     0.0%
 Result URL: https://www.speedtest.net/result/c/86c702a3-6d7b-45c1-ac8b-0aa58bfdd3de
Have you got Viewquest support to look at your connection issue? If you can not get normal wired download speed to be above 850Mbps at any time for 1Gbps plan, there is an issue already. That is regardless of the ISP used.
firesong
Deluxe Member
I'm a bit surprised by it too. These are with the limiter arbitrarily set to 980. Not sure if it made any difference. Also, the Khadas VIM3L is pretty capable, definitely a bit more powerful than the RPi4.
Am testing a modified script to export to csv automatically, but am trying to make sense of the output. Just throwing numbers around, it seems I can just divide by 125000.95 to convert the result to Mbps, though it's not quite accurate. I have no idea why that's the factor, though. :s13: If anyone can shed light on how to derive the final Mbps output, I would be very grateful.
It's easier to manipulate the outcomes in Excel with it all tabulated nicely in a .csv rather than a wall of text.
Code:
# csvspdtst.sh
# Automatically pipes outputs to results-YYYYmdd.csv.
# Each run will overwrite existing file by the same name.
#!/bin/bash
# Set output file in results subdirectory
RS=./results/results-`date +'%Y%m%d'`.csv
# Singtel
speedtest -fcsv -uMbps --output-header -s25960 > $RS
# ViewQuest SG
speedtest -fcsv -uMbps -s2054 >> $RS
speedtest -fcsv -uMbps -s7556 >> $RS
speedtest -fcsv -uMbps -s9436 >> $RS
speedtest -fcsv -uMbps -s16974 >> $RS
speedtest -fcsv -uMbps -s16089 >> $RS
speedtest -fcsv -uMbps -s30932 >> $RS
speedtest -fcsv -uMbps -s44988 >> $RS
speedtest -fcsv -uMbps -s13902 >> $RS
# Celcom Axiata - Kuala Lumpur
speedtest -fcsv -uMbps -s4956 >> $RS
speedtest -fcsv -uMbps -s17402 >> $RS
speedtest -fcsv -uMbps -s44340 >> $RS
Quick manupulation of the original output (above) with the duplicated+formulae'd output below:
Edit:
- V2. Added a date component to the filename. It can now be run as a daily crontab with the necessary modifications. ;) Add %H%M%S" if you want the time also - but export filename to a variable and reuse that variable for filename in each line instead so you have a single file each run.
firesong
Deluxe Member
As requested by @rubicon, Speedtest on Singtel at 10pm on a Saturday night. Network under light load - one Netflix, two surfing textual sites. Ubuntu server on a ethernet connection, direct to switch.
ServerLatencyDownloadUploadLossShare URL
Singtel - Singapore (id = 25960)1.69ms (Jitter = 0.08ms)948.3Mbps (data used: 7.2GB)945.07Mbps (data used: 9.0GB)0.00%https://www.speedtest.net/result/c/9b4333aa-d953-4084-8257-f00cde35b68d
ViewQwest - Singapore (id = 2054)6.32ms (Jitter = 1.06ms)932.04Mbps (data used: 5.3GB)933.98Mbps (data used: 8.9GB)0.00%https://www.speedtest.net/result/c/ac5ef3e3-b82a-4476-9e49-964459b0b273
PT FirstMedia - Singapore (id = 7556)1.92ms (Jitter = 0.13ms)935.85Mbps (data used: 3.9GB)935.76Mbps (data used: 9.6GB)N/Ahttps://www.speedtest.net/result/c/db281191-dda7-412e-a877-76bf00a463ad
Comcast - Sacramento, CA (id = 9436)189.49ms (Jitter = 0.16ms)842.63Mbps (data used: 10.8GB)119.97Mbps (data used: 1.7GB)0.00%https://www.speedtest.net/result/c/b23d8bb7-7f02-4485-aa4a-389dd2d3a50d
Spectrum - Los Angeles, CA (id = 16974)194.46ms (Jitter = 0.16ms)910.71Mbps (data used: 11.3GB)143.4Mbps (data used: 1.6GB)0.00%https://www.speedtest.net/result/c/94cabfba-7c60-4b0e-b606-23bcabb60ae4
University of Texas, Austin - Austin, TX (id = 16089)218.02ms (Jitter = 0.13ms)351.02Mbps (data used: 4.0GB)35.18Mbps (data used: 0.5GB)0.00%https://www.speedtest.net/result/c/ca9a1e32-1aff-4a8c-ab97-b45e4762c90e
Optus - Melbourne (id = 30932)109.36ms (Jitter = 0.14ms)946.95Mbps (data used: 12.8GB)247.05Mbps (data used: 3.5GB)0.00%https://www.speedtest.net/result/c/e3f34627-a8c7-49da-b29d-60ba15dd81d2
Misaka Network, Inc. - Tokyo (id = 44988)80.84ms (Jitter = 0.37ms)940.0Mbps (data used: 12.8GB)281.46Mbps (data used: 2.9GB)0.00%https://www.speedtest.net/result/c/91a167ce-36ac-46e2-872e-1c4f04cd1b4e
SIMPLYCONNECT - Dar es Salaam (id = 13902)451.37ms (Jitter = 3.77ms)5.09Mbps (data used: 0.1GB)8.03Mbps (data used: 0.1GB)0.00%https://www.speedtest.net/result/c/b5acd500-d4a9-42ad-94d5-54beddb3a818
Celcom Axiata - Kuala Lumpur (id = 4956)236.98ms (Jitter = 0.08ms)481.58Mbps (data used: 5.5GB)133.41Mbps (data used: 1.2GB)0.00%https://www.speedtest.net/result/c/31c9e040-f3ff-486d-9a57-5e7e4afe6336
Bell Mobility - Vancouver, BC (id = 17402)247.86ms (Jitter = 0.07ms)897.7Mbps (data used: 10.1GB)110.4Mbps (data used: 1.5GB)0.00%https://www.speedtest.net/result/c/45b6af1e-316a-4d34-ae56-89b8bc0cea98
Telstra International - Hong Kong (id = 44340)34.26ms (Jitter = 0.11ms)930.79Mbps (data used: 8.5GB)377.14Mbps (data used: 3.8GB)0.00%https://www.speedtest.net/result/c/d5d9f42f-4f49-42bd-944c-7a176291e5c1
PS: Figured out the formula is a hard 1/8 of 1,000,000. Thanks again @xiaofan. Updated the formula.
Have created an Excel sheet that automatically imports the numbers from the export csv, converts the numbers to a more human-readable format.
Update2: Created a new sheet that changes the layout of presented data to match the CLI output. Simple concatenation and text formatting formulae (See screenshot)
Link to Excel file: https://file.io/tIUbNTBew8CQ
Open it, go to Data -> Refresh. Select your exported CSV and it should automatically fill and format the data. Go to Alternate tab, copy/paste in HWZ. Done. :)
x/125000 = x * 8 / 1,000,000 seems to be a simple conversion from B/s to Mbps. Looks like -uMbps has no impact for the csv format.
My SIngtel test results at around 10pm, with an Intel J4105 PC running Ubuntu 21.10.
Singtel ZTE ONT -- TP-Link TL-SG105E smart switch -- Asus RT-AX82U router -- Intel J4105 mini PC running Ubuntu Linux 21.10 64bit
server nameserver idlatencyjitterpacket lossdownload Mbpsupload Mbpsdownload MBupload MBshare url
Singtel - Singapore
25960​
1.867​
0.039​
0​
938.368968​
946.71904​
807.92166​
1115.792324​
https://www.speedtest.net/result/c/5048f91e-41c9-465e-bafc-a8057dd28bec
2054​
5.428​
0.864​
0​
878.407056​
936.063352​
1137.377936​
1185.406541​
https://www.speedtest.net/result/c/e8f219c5-2ebd-4473-a399-9a0491878ae0
7556​
2.522​
0.28​
N/A
933.320576​
938.508104​
444.672112​
1106.657973​
https://www.speedtest.net/result/c/94105964-cee8-4d4c-9801-cecb2ecd5131
9436​
198.326​
0.152​
0​
351.70848​
283.851464​
527.73084​
483.353688​
https://www.speedtest.net/result/c/c7712f58-6c7e-44e0-b0db-79cb2022f55b
16974​
164.595​
0.223​
0​
335.681464​
344.879856​
523.863232​
567.156755​
https://www.speedtest.net/result/c/b279124f-3ded-4442-9253-bc91d8a98098
16089​
264.267​
0.236​
0​
285.35936​
120.812​
449.303144​
208.765314​
https://www.speedtest.net/result/c/bef7022a-829b-4a4b-a57d-bc16da4c2c7c
Optus - Melbourne
30932​
108.83​
0.202​
0​
813.19268​
509.430408​
1276.416344​
550.80654​
https://www.speedtest.net/result/c/6ac07a15-3865-4761-8114-b2ab01aec8e9
44988​
85.227​
0.159​
0​
526.027912​
560.441384​
585.4988​
787.439554​
https://www.speedtest.net/result/c/9a7af9cd-c1bf-4154-8c41-3f610df4a4ab
13902​
438​
0.567​
0​
7.478984​
16.845984​
5.764488​
29.080789​
https://www.speedtest.net/result/c/cdac9f08-faa0-44c6-aaf4-e9352bf43189
4956​
233.2​
0.174​
0​
550.45116​
212.121408​
904.54144​
358.483806​
https://www.speedtest.net/result/c/b2e976cd-2336-4ce6-aaeb-b1f0099c1a3b
17402​
244.484​
0.183​
0​
416.408144​
195.538656​
578.468016​
297.760321​
https://www.speedtest.net/result/c/ff4d3abb-abdb-4e83-89f8-540a88b0fc3d
44340​
34.438​
0.207​
0​
829.907304​
936.158784​
1420.131904​
1228.522008​
https://www.speedtest.net/result/c/d931405b-a23c-41a1-b52f-5413625a77e4
firesong
Deluxe Member
DUH! Of course 12.5 is an 8th relationship. Thanks @xiaofan ! Feeling quite foolish now. :s13:
Subconsciously, I kept thinking "I know there's a relationship.... there has gotta be a relationship." But I was stuck thinking of 1024s.
miloaisdino
here are my set of m1 results! not too bad
Speedtest by Ookla
ISP: M1
Latency: 3.68 ms (0.09 ms jitter)
Download: 932.26 Mbps (data used: 421.9 MB)
Upload: 796.24 Mbps (data used: 409.1 MB)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/34093d35-e784-45f9-9927-b831f9cc9443
Speedtest by Ookla
ISP: M1
Latency: 2.60 ms (0.05 ms jitter)
Download: 931.29 Mbps (data used: 927.2 MB)
Upload: 797.61 Mbps (data used: 401.3 MB)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/f59b394d-e3a5-4518-8470-3985fd7423c3
Speedtest by Ookla
ISP: M1
Latency: 2.25 ms (0.14 ms jitter)
Download: 934.47 Mbps (data used: 457.0 MB)
Upload: 812.35 Mbps (data used: 395.8 MB)
Result URL: https://www.speedtest.net/result/c/f7263f9c-e383-438f-a9f6-7749120c9e99
Speedtest by Ookla
ISP: M1
Latency: 178.41 ms (0.40 ms jitter)
Download: 840.15 Mbps (data used: 1.2 GB)
Upload: 194.45 Mbps (data used: 345.5 MB)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/076cd092-a91c-4603-8bde-296cc69f08af
Speedtest by Ookla
ISP: M1
Latency: 170.44 ms (0.07 ms jitter)
Download: 705.01 Mbps (data used: 866.4 MB)
Upload: 175.74 Mbps (data used: 189.1 MB)
Packet Loss: 0.0%
Speedtest by Ookla
ISP: M1
Latency: 200.87 ms (0.50 ms jitter)
Download: 60.83 Mbps (data used: 92.4 MB)
Upload: 27.49 Mbps (data used: 53.4 MB)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/41dbff51-3a8a-45db-99be-4c7116d69461
Speedtest by Ookla
ISP: M1
Latency: 144.50 ms (7.42 ms jitter)
Download: 72.25 Mbps (data used: 99.3 MB)
Upload: 187.38 Mbps (data used: 322.3 MB)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/8c5b752c-cc74-46d1-b517-c62a68d0a54f
Speedtest by Ookla
ISP: M1
Latency: 112.51 ms (13.14 ms jitter)
Download: 969.63 Mbps (data used: 1.5 GB)
Upload: 139.45 Mbps (data used: 222.9 MB)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/2da683f4-8513-4350-8d59-111d59c09b34
Speedtest by Ookla
ISP: M1
Latency: 266.90 ms (0.22 ms jitter)
Download: 6.59 Mbps (data used: 9.5 MB)
Upload: 25.65 Mbps (data used: 43.3 MB)
Packet Loss: 0.3%
Result URL: https://www.speedtest.net/result/c/d273df13-1598-4dd4-916f-ed0181895ed7
Speedtest by Ookla
ISP: M1
Latency: 230.18 ms (0.31 ms jitter)
Download: 764.72 Mbps (data used: 1.1 GB)
Upload: 169.85 Mbps (data used: 283.6 MB)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/83bf175e-e57e-43c9-8902-8c983dd41161
Speedtest by Ookla
ISP: M1
Latency: 31.91 ms (0.08 ms jitter)
Download: 915.16 Mbps (data used: 1.2 GB)
Upload: 218.35 Mbps (data used: 398.4 MB)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/5040d173-fd4f-4726-8bb8-08d29c5ac295
moral of story: m1 international upload is capped at 200mbps
note: upload does not exceed 800mbps due to bufferbloat qos on my side
