garychengjw
- Jul 18, 2010
Offloading or wait for Dec update?
Using lah. My 4XL kichar already
On the other hand I tried to install the hydrogel screen protector and I just can't so it without dust getting under it. Anybody have a shop to recommend for installation?
I choose Use the address as it is.How u all do cgw direct Google Store when the cgw cannot be saved or entered at the checkout point. It will show cannot deliver to this address
Did you follow professional guide to install?![]()
Where did you install at?Finally got my p6p installed dbrand skin and it looks fantastic and not slippery.
I bought it from dbrand store and installed it myself very easyWhere did you install at?
The phone does get warm easily. Abit turn off
wa looks good! Using naked?
That 2 Cortex X1 cores areLooking at it. the battery transfer heat via the flim to the aluminium plate. the soc also transfer heat to the plate (no vapor chamber). if excessive heavy usage or using demanding app, the plate gets so hot and thus causing the phone to get a bit warm. machiam transfer heat from one another and passing back![]()
That 2 Cortex X1 cores are![]()
No leh don't dare, using ringke clear casewa looks good! Using naked?
