zero1 is singtel right?Same price just try try, so far not much different in speed
zero1 can always port back mah
never like zero1 ... my 1st mvno ...zero1 is singtel right?
i actually switched to TPG from GOMO, find TPG quite lacking in terms of speed and signal.
want to try zero1. any review?
I see their fb page reviews all like ****.
TPG doesn't have eSIM support, for any devices.Does TPG have eSIM feature for Samsung Galaxy Watch 4?
Yes, Zero1 quite ok, no problems with data speed, after 6gb is still usable, fb ig tracetogether whatsapp as per normal, but of course not fast enough not for HD video streaming or ig storieszero1 is singtel right?
You got to test yourself to confirm. At most just use the TPG voice appCurious, anyone using TPG on a Pixel? Is the VoLTE profile native or do you need to use the 4G Voice app?
I'm getting conflicting info from reading all over, so would like to know. Some say yes, some say no.
Would be good also to indicate which model, and which Android version (11/12).
Mom's not been letting me touch her TPG SIM card since she's picked up Pokemon Go. :/
Yah that was what i think too.Yes, Zero1 quite ok, no problems with data speed, after 6gb is still usable, fb ig tracetogether whatsapp as per normal, but of course not fast enough not for HD video streaming or ig stories
FB complaints all are FW, maybe they subscribe the cheapest plan, expected unlimited data speed as fast as before 6gb
After you collected your SIM card, the port in process will be triggered and you will receive an email about the port-in too.I applied tpg and choose to self collect the SIM card at one of the locations. May I know how will the porting be triggered? Do I need to login somewhere to select porting or will it be auto after collection of SIM card?
Thx.
Zero1 use Singtel but not the same as Singtel own plan. Used it before and port out cause in some places official Singtel got signal but not zero1.zero1 is singtel right?
Finally got hold of mom's card for a few moments.You got to test yourself to confirm. At most just use the TPG voice app
In what scenario will VoLTE icon disappeared by itself?
I suddenly just realized the VoLTE icon gone from my xm note 6 pro duno since when gone meaning if someone tried calling me can't get through.![]()
I re-enter the *# check enabled then again repeat check disabled + reboot then the voLTE resurface.
TPG not that compatible with my hp gonna port out soon.
I also got the habit of switching off WiFi when not using wifi anymore. Duno since when the icon gone wo me knowing.Only when my wifi switch on at home, volte status missing, I tested the callin in still works.
When i left my hse, I will switchoff the wifi on phone, I did not notice my volte missing.
Strange thing my phone unable to smoothly switch bands. When i walking towards my office toilet, signal getting weaker, in toilet no signal. But when i press airplane mode and back got 2/3 bar signal
I am using XM Mi note 10
Maybe your phone sw problem, try do a full resetI also got the habit of switching off WiFi when not using wifi anymore. Duno since when the icon gone wo me knowing.
Just now when I finally noticed voLTe icon missingI tried calling myself via another phone is not working i.e. switch off mode via the automated voice. I press the *# the check is still disabled but icon gone.
Cannot lah must port out wait later SS Kim Ng zz call me how?![]()
If your line is expired (no payments made), you have up to 21 days (for SIM Only Plans) or 30 days (for Prepaid) to renew.Hi, I barely use my TPG number as I am mostly at home. What will happen to my TPG number if I stop recharging/prepaying/renewing for 1-3 months? Will they terminate/disable my personal number permanently or can I recharge/reactivate it again after 1-3 months of not paying?
