trenzterra
- Sep 18, 2002
Looking at keycool 84... Hotswap likemore funWhich Bluetooth keyboard you plan to get or still going for the Niz plum?
anne pro2 quite old liaohey guys, my filco majestouch 2 is registering multiple inputs upon single press on certain letters, so am looking to replace.
am looking at rk61 or anne pro 2. anyone whom have used both can give some feedbacks on both?
First time see ppl go for Gateron Browns/Reds when going for GMMK keyboards :XJust ordered the THe Glorius GMMK RGB Modular set with Brown & Red Gateron switches on Lazada. Hope its good!
https://www.lazada.sg/products/the-...ze-tkl-compact-60-i385092951-s910436239.html?
Hi. It has been quite some time since i last touch my PC. Is there any PBT keycaps available now for logitech G915 TKL wireless ?
usually what switches for GMMK keyboards?First time see ppl go for Gateron Browns/Reds when going for GMMK keyboards :X
G switches by Logitech. Propriety. Not many keycaps available for those. Logitech itself may have some variety of those keycaps, but it's going to be very limited in choices.
People usually go for more expensive switches.usually what switches for GMMK keyboards?
I'm using them, gateron browns. Its good, battery last long but there's 1 thing i super don't like is that the usb cable connection is at the bottom of the keyboard. Its difficult to plug in and out the cable. I prefer keychron's design where it is at the side.Looking at keycool 84... Hotswap likemore fun
Where did you bought it from? Are there any keyboards identical to this in terms of the layout of the keys?I'm using them, gateron browns. Its good, battery last long but there's 1 thing i super don't like is that the usb cable connection is at the bottom of the keyboard. Its difficult to plug in and out the cable. I prefer keychron's design where it is at the side.
Not OP,Where did you bought it from? Are there any keyboards identical to this in terms of the layout of the keys?
Not OP,
but Keychron and RoyalKludge has the same layout.
Keychron K2 and RK84
There's also Akko 3084, EPOMAKER EP84, Tofu 84, XD84 Pro.
Just google 84% keyboard and you'll find a few.
Sorry, never seen any before. Hopefully others may be able to help you.Thanks for the recommendations. Any idea if there are any low profile 84% keyboards besides the Keychron?
i believe xd84 is low profile? else vortex race 3Thanks for the recommendations. Any idea if there are any low profile 84% keyboards besides the Keychron?
Same like me, looking at RK61 or Anne Pro 2 for a new KB. To be honest with you, RK61 have more plus points over Anne pro 2.hey guys, my filco majestouch 2 is registering multiple inputs upon single press on certain letters, so am looking to replace.
Bought it long time ago from gamersmart at plaza sing. Yeah, key layout is the same. I bought keycool because I couldn't find available stock for the keychron model i wanted.Where did you bought it from? Are there any keyboards identical to this in terms of the layout of the keys?
Interesting, I thought it's finally becoming mainstream thanks to the gmmk pro and keychron q1.i believe xd84 is low profile? else vortex race 3
the "kbd75" layout has fallen out of favour in recent years, with most preferring the split cluster/65% blocker layouts.
