- Sep 16, 2018
It's actually pretty simple on Docker. But yes, it does need a constantly up device. A PiHole or a NAS is fabulous for this. But running it on your PC isn't too bad since it gives an idea of the PC's connectivity as long as it is up.
I'll drop my sanitised docker-compose.yml file for anyone to modify and use - to shorten the setup time. Stipulate the port you want it to run on
The only other files that need to be edited are the 2 files under ./config, General and Targets
A sanitised Targets file. Feel free to modify and use.
Nice one. Looks like this will be my next learning exercise for using Docker. Right now my Intel J4105 mini PC is always on, running Ubuntu and then connected to my two routers.
Just wondering if you can add speedtest in the mix to kind of measure the bufferbloat as well, i.e., to provide an option to run smokeping while running speedtest.
