Car mats recommendation?
sTiCkY
was looking at passorex but like a bit ex...
anyone got recommendations/comments for reasonably priced car mats?
sinicker
On Carousell look for carmatsl2singapore.
every 2 years new mats from him.
renfred89
i'm using the 3D maxpider car mat. i chose this is because of its durability and the fact its like a plastic tray with furry carpet feel. car mat need not be expensive to serve its purpose but need to be safe. safe is defined as not capable of interfering with the pedals..
EJB
That depends on your placement of the mats... how do mats affect pedals if you get the correct sized ones for the car?
myviowner
Starting from $3xx+ and up, at least?
Gotton over online, $100+. 5D type. Cover up to the door sides. Tear also dun mind, replace again.
myviowner
Though going for periodical interior sanitization service, usually I will discard the mats after a period of time. Hygiene reasons. Pocket frdy ones i go for.
adrianloh
Stock the best??? fabric leh... when your shoes are wet after heavy downpour, the carpet will be wet and if it cant dries fast enuf in the long run whole car will have musky smell.
koster
If for water proof purpose, rubber mat will be better I suppose.
Eviltrap
I installed the Enzo mats about 2 weeks back. From a group buy with my car group.
So far, feels ok. Very grippy coz all rubber (or whatever synthetic rubber material). Got many holes, so not sure whether will gravel get trapped inside and can't be removed easily. So far, wife said vacuuming was easy to remove the dirt.
Maybe still early, but still preferred my previous Matters mat. But no longer in business, so settled for this when the car group did a group buy.
koster
Wow thought Matters is doing well. Surprised they are no longer in business.
EJB
Really, so mats that trap water don't need to clear the water also? You mean the water will magically evaporate once it reaches the mat?
