VIVIFI
xerref
Ok so I’ve submitted request for port over on 23, and activated today at 130pm. When should I use the new sim?
xerref
Alamak they send me a micro sim instead of a nano sim
did I **** up the selection?
xerref
Thanks, fixed it
noticed the 4g speeds are pretty slow though
the upload stuck
Think I am having problem porting from StarHub (it used to be a corporate line), despite the staff had activated for me and I have already submitted the porting request before 630pm ,how ah?
chaiscool
Activated what time? Think both activation and port in must be before 6:30. Mine from ST FOSS line port in no issue, check your port in status on the portal?
1982-1994
Thanks
have successfully ported over
1982-1994
Thanks, fixed it
the upload stuck
I have tried the speed test on Huawei and iPhone with the latter hitting 200mbps while 70+ on the other
Really fast, even faster than SingTel itself
xerref
Weird, not sure why I’m getting these speeds on my iPhone
xerref
alamak now no reception in some rooms. Starting to regret the switch
chaiscool
Ya, it auto switch to 3G, but some place zero bar.
If zero bar only at home and other place no problem then you cannot use singtel mvno. Try StarHub giga, hopefully can.
Might have early termination charges though, iirc vivifi has 2 months minimum
