VIVIFI
lohsenglte
Yes, checked. Reinsert SIM card, reset etc
Means likely your area singtel isn’t covering properly.
consider switching to StarHub or M1 (and MVNO counterparts).
If you want to try M1, i can share a deal where you use until end-Feb for $3-4/mth, 50GB. Thereafter, $18/mth.
If CL is ok, then transfer to MR or any other M1/MVNO if rates are cheaper.
rubicon
considering porting my main number over.
anyone has issues with OTP SMS:
- dbs
- uob
- citibank
thanks
Teo Ming Ern
Typical support, heng I only on the cheapest plan. Ported old number from TPG, first week of Nov receive sim card and activated, immediately started having issues with OTP SMS, email their support after a couple of days, give the typical reply we're looking into it blah blah, then no response. Wait until today then they close the case with the usual we check everything ok on our side blah blah. Either I the only bugger damn unlucky or...
Your problem seems to stem from TPG... porting over from the main telcos like M1, Starhub or Singtel or their own MVNOs is problem-free...
Teo Ming Ern
Got like that one meh? I though Singtel has the best coverage?
vsvs24
actually not bad. $40 if add one subline $6.
meaning $46 for 2 no to share 180GB? not too bad.
Wonder if it is better to diversify especially now may need to work from home for work or school. In case wifi and mobile line of the telco down, at least if have other telco lines can still hotspot.
Also depends on needs. If all 4 low usage, 8.80 or 9.80 plans works out almost the same price.
hereiam7788
redundancy for lion city context is not so crucial I would say.
The chance for network to be down is still very very low I would say. Plus most ppl have fibre broadband at home and wifi at work. Dun think it is so important. Haha.
hereiam7788
I'm pretty sure I've heard before people with almost zero SingTel signal in their flat.
In general, SingTel LTE is better than others, but doesn't mean it is always the case.
It is true becos it is called blind spots but cannot deny that Singtel and StarHub have generally much better coverage and speed than M1 in most areas. Based on IMDA and the statistics can confirm this also. While it is not possible to guarantee 100% coverage and speed for all areas. Having relatively better overall coverage and speed will likely to bring better user experience.
ColorCode
How long does the whole process takes when I switches from Singtel to vivifi? What are the things to take note? My current Singtel contract ended on a public holiday. Thanks
