Pocophone F3
justln
Installed crDroid after a crap ton of troubleshooting with Slot A/B and TWRP fastboot etc etc, almost thought I bricked my phone. :s13:
So far so good, nice ROM. Need to finish setting it up.
KeYoKe
Any issues with banking/singpass/gpay app?
safetynet passes ootb
As long as you dont root it, all can be used
Even if u root it, there is magiskhide, BUT some apps like singpass still able to detect root even when u magiskhide it. So best to just use it and dont root it
OutBreak
Singpass so smart? Incredible.. :ROFLMAO:
KeYoKe
Not just singpass ba, some banking apps too like citibank. So far uob, posb still ok
Grab lagi best, lure u to click on the allow root access prompt when u launch the app the first time. If u click allow accidentally, gg
PES1989
My Healthy 365 app from HPB detected that my device is rooted & barred me from using the app. Means need to install magisk to bypass it?
KeYoKe
U rooted? Or jus flash custom rom? If flash custom rom only should be able to use leh
Can try to root it. Install magisk apk via twrp. At magisk setting enable magisk hide. Try to hide it see if it can work. If cant work then... Gg
PES1989
Only flash custom rom via OrangeFox recovery. Didn't root at all.
Hailgod
KeYoKe
tip from a fairly long time xiaomi user. dont do it guys.
wait for other people to complain about the bugs, then a few more months till it gets fixed (if it does).
when its bug free again then update
Even got new update dont update immediately regardless is jus a monthly patch or what :s22:
justln
Have to agree, the last MIUI update on my POCO X3 NFC broke full screen gestures on 3rd party launchers which is why I bought POCO F3 to get custom ROM right at the start.
