According to jbl experts, ideally 1.5m -1.8m from the ground pointing in direction of ears. So yes can go bit higher if ceiling is not too high. The ceiling sound reflections interference might be of concern though depending how u mount.If my sofa going to park next to wall. My surround next better placement can it be ceiling speakers ?
Wah your home so neat and nice! Well done!Setup this system 3 months ago with advice from folks here. Quite happy with it, but I need a rug (have been putting off buying it)
It looks like Q acousticsU are using what speakers for your living room setup?
Thanks. All thanks to the wife, who wants a neat setup with as few things shown as possible, so cable management was key (all hidden in walls/false ceilings). The colour and look of the speakers also had to match the theme.Wah your home so neat and nice! Well done!
Yup, Q Acoustics 3020i front speakers, 3090Ci centre, 3010i rears, Polk HTS10 sub, Denon AVR-X1600H, and Prism+ Q65QE Pro TVIt looks like Q acoustics
I'm a SVS fanboy![]()
Can't remember where I read they say 3700h has same electronics as 4700h. So I would say just buy 3700h and get dual subwoofer instead. Although u do need space for that.Planning to upgrade my current x3400h to 700h series to make use of pre amp mode as I have a 8 chn hypex amp coming.
should I go for 3700h or 4700h? Will only be running 7 chn for the time being and when shifted will likely get another 4 chn amp so the avr will be used as pre amp only.
not too sure if it’s worth to pay 700 more just for aura 3D
Dual sub are in the plan. Slowly upgrading until shift house so that lesser things to buy. Currently using kc62 so ya won’t take up much space even if add in 1 more.Can't remember where I read they say 3700h has same electronics as 4700h. So I would say just buy 3700h and get dual subwoofer instead. Although u do need space for that.
Yah then 3700h. If not then x8500h which allows u to turn off any or all internal amp so u can use all your 8ch hypex power amps. Hehe.Dual sub are in the plan. Slowly upgrading until shift house so that lesser things to buy. Currently using kc62 so ya won’t take up much space even if add in 1 more.
Was looking at the 8500. But very chor.Yah then 3700h. If not then x8500h which allows u to turn off any or all internal amp so u can use all your 8ch hypex power amps. Hehe.
Ya understand, so much things to upgrade but too little money.I think dual subs really make huge difference to me. After I added 2nd sub I think can hear more mid bass sort of. Previously with single sub I mostly heard low low bass and mid bass sounded too soft.
U rich siah. I would have cancelled the hypex amp heheh. Some say makes little to no difference.Ya understand, so much things to upgrade but too little money.
every month add in things, think I can go stay in living room already.
mad the hypex amp will only likely to reach me in April. I’m thinking if I should get a pair of ls 50 meta first or change my avr first.
once those are done, will add in a r2c and another kc62. Rest can only be done after shifting which hopefully will be early 2023.
