Recommendations for fridges
Sherra
Can anyone recommend a good fridge for top mounted, 500l-ish capacity?
Went hn, was recommended the Toshiba fridges...
Don't know is sales talks or legit advice. Haha
itchying
Hi my fridge is not cold n not making noise anymore at the back. Can still fix? How much?
If buy a new one still can tradein?
Tia
darcbleu
Anyone has recommendation for side by side fridge? which brand to your experience is good and where to get them? Audio House or budget store?
itchying
I would call the brand company if you still have warranty. Otherwise, it might be more cost effective to buy a new fridge.
Just to update that i fixed myself by switching power off the fridge for half a day. I think the fridge defrost or reset itself n it back cool again. I think the same logic might apply to aircon too if there something wrong with the pcb. Can try do to db n off the switch of the aircon. Last time the aircon motor couldnt stop turning so did this way.
beary2teddy
I’m looking for ~400L fridge with the freezer at the top, budget about $1k. Is there any recommendation?
Melodygoh
Anyone knows which are the brands than can change the fridge door direction? Looking for one that opens to left hand side.
lai_cc
Hi,
Been looking around for fridge to fit small kitchen. Am looking for either 3 door or 5/6 door fridge.
3 door fridge normally do not have ice maker (except 1 model from mitsubishi) and the bottom freezer compartment is quite deep to reach. But for 6door the price jump is more than double.
Anyone used the 6 door hitachi or mitsubishi or panasonic? what is your experience?
scenium
Anyone here uses a Toshiba French Door Fridge GR-RF532WEPGX? I just bought 1 and after few weeks of using notice that there is a rattling noise coming from behind the fridge. Any experience this?
LiLAsN
That's not good. By right, with any fridges, when they are transporting, there is a thing that is connected to the fridge so that all the components in the fridge will not sway or get damaged by a lot of hard movements during transport.
But the moment it is in place and will no longer be moved at your house, that thing is removed. But.... All the people who ever sent the fridges will always say not to turn on the fridge for 30 or even up to 1 hour after letting the fridge lie still. Only after that, can you turn on the fridge.
Did you miss that step mentioned? If you did, this is what will cause your motor to now experience the rattling sound. Best for you to use either the shop you bought it from to fix or replace or get Toshiba to do it asap before they deem it way too long and you can't get a replacement. (typically up to 7 days from the store you bought it from)
