iPhone 13 Series
maple_mak
Today Phone locked and screen off at around 3am at 85%. 530pm on phone to check screen to see battery at 80%.
drop of 5% overnight.
should i exchange my phone or??
Saw your signal strength. Bad signal reception is also one of the main causes of battery drain too...
mousepad_88
Expected at this early stage of Android 12! 😬 Certain apps and functions are still a bit "retarded" at the moment! 🤭
My Fingerprint icon also failed to show up frequently LOL! 🤭
I guess this has to be fixed by subsequent Apple software updates? Its getting pretty bad for mine, when taking photo, the image can get blurry suddenly and video recording halfway video sometime will just blur suddenly as well.
szeli
doesn’t sound right. log case with  support?
szeli
Someone else before that suggested i turn on airplane mode. Tried that as well. Phone also drain 3-5% overnight in airplane mode
maybe time to log a case with  support. shouldn't drain while in airplane mode..
Snoweagle
Agree that it shouldn't be. I've tried airplane mode overnight on my 13 Pro Max, maintaining 100% after over 8hrs.
But it's not the same on my Z Flip3, which drops 4% in the same mode.
Charlie_Zhan
i used to be a samsung user. that phone, even you turn it off it will also drain battery overnight, let alone airplane mode. 😂
Read HWZ Forum Rules!
ragnarok95
Senior Moderator
Senior Moderator
If you think the battery has an issue after a period of testing, it's best to let Apple have a look rather than waiting for more replies here.
dappercivility
Anyone using the HKG Set iPhone 13 Pro Max, I was using the local iPhone 13 Pro Max and today swapped over to the HKG set with the physical dual sim and found reception is not as good, noticeable difference. Anyone knows if the HKG set does not fully support all the local telco 5G bands?
**Edit: Just checked Apple's Webpage on the various models bands, Singapore is A2643 and Hong Kong is A2644, their frequency bands should be identical. Maybe need to monitor a couple of days to see.**
I'm currently using Singtel and Starhub on my iPhone 13 Pro Max.
kEvinErd
Anyone else’s “Frequently Visited” disappeared on your Safari? Is there a way to get it back without resorting to a drastic factory reset?
007Mi6
I am assuming that your previous experience is on a SG iPhone 13 Pro Max where you insert 1 SIM card? Of course there will be differences where if you have dual SIM card turning on at the same time, it will not be as good as ST would be using one band instead of 2-3 bands while SH uses the other available band not used by ST.
dappercivility
Yes you are right. I had always assumed that with 2 imei and allowing dual sim, each sim with have standalone bands. After your explanation, I would guess you are right on dual sim shares each network band. Hopefully future variants would have standalone network bands for each sim
rerear
Any color of the 13 pro max 256gb is more expensive, or all the same price regardless of color?
