⚡️💻 [Official] README First! 2026 SG ISP Comparison & Latest Promo Deals! ✨
Please read Post #2, #3, #4, #8 and #10 for more details.
You may also read the posts in the last two pages to see if there are any new offers not mentioned in this page.
Last updated on 5-March-2026
One important development in 2025 -- Starhub is now #1 and the market is getting more competitive.
Starhub (including MR and eight, but eight is new) is now #1 in Consumer Fibre Internet Market, taking over Singtel's #1 position. Starhub is struggling in the mobile market and it will lose its #2 position once the merger of SIMBA and M1 got the approval and complete later. But for Consumer Fibre Broadband, it will still hold #1 postion as SIMBA has negligible market share in the Fibre Broadband market.
Reference from Starhub Finance Update.
https://ir.starhub.com/results.html
Q3 2025 (eight home internet did not exist then).
https://ir.starhub.com/newsroom/20251114_072129_CC3_HAHXO8FQMCOXQ3L9.1.pdf
FY2025 full year results
https://ir.starhub.com/newsroom/20260212_072316_CC3_6WSP5L91T8493ZIH.3.pdf
1. Recommendation for ISP Plans to Go
Updates for Year 2025/2026. The following are just my personal opinion. YMMV.
1) For existing users of any ISPs: no switching of ISP unless if you got issues or you got good offers from the other ISPs.
This is even true for Singtel users -- if you are fine with your Singtel Fibre internet plan using ONR, no need to change, even though I do not recommend new users to go with Singtel because of the use of ONR and relatively higher cost compared to other ISPs.
However, as per the updates from Singtel thread on 12-Dec-2024, Singtel does not allow recontract of ONT based plan (legacy 1Gbps plan) any more -- it is better for Singtel ONT users who want to keep using ONT with their own router to consider switching to other ISPs using ONT.
https://forums.hardwarezone.com.sg/threads/singtel-1-gbps-fibre.5930834/page-253
2) Recommendation for new sign-up:
You should go through Post #3 to see which plan you like better. Post #2 and Post #4 are worth reading as well.
Typically I will recommend M1 or Starhub to new sign-ups.
3) For Dual ISP users:
ST+WC combination is not recommended because WC uses ST infrastructure.
SH+eight combination is not recommended since eight is a subsidiary of Starhub and use Starhub infrastructure.
SH+MR (or MR + eight) may not be recommended since SH/MR seem to be merging the backend.
II. Details of ISP Fibre Internet offerings
1. SingTel : (2Gbps/3Gbps/5Gbps/10Gbps plan, legacy 500Mbps/1Gbps/2.5Gbps plan)
Public IPv4: yes, no static add-on
Updated on 12-Dec-2024, Singtel does not allow recontract of ONT based plan (legacy 1Gbps plan) any more -- it is better for Singtel ONT users who want to keep using ONT with their own router to consider switching to other ISPs using ONT.
Update on 18-Feb-2025: Singtel now offers XGS-PON ONR bridging at S$10 per month.
Updated on 1-Nov-2025, Singtel stops to entertain ONR bridging request, they have changed the terms and conditions to mention the following:
"Bridge Mode is temporarily not supported on this plan and there can be no reversion to previous plans that offered “Bridge Mode”.
You may be able to bridge the GPON or XGS-PON ONR by yourself. Proceed at your own risk. YMMV.
Legacy ONT users: the user is able to configure native IPv6 on their own router. Singtel VLAN settings need to be done for Fibre Internet and Singtel TV Box (if any).
ONR users: Native IPv6 (/56) is availble and but ONR users may not be configured with native IPv6 by default. You have to request Singtel to provision it. Please refer to the following thread.
https://forums.hardwarezone.com.sg/threads/singtel-5gbps-ipv6.7053976/
Singtel 2Gbps plan: aggregated 2Gbps, must use Singtel GPON ONR.
Singtel 2.5Gbps plan (only offered to some recontract customers previously) : aggregated 2.5Gbps, must use Singtel GPON ONR.
Singtel 3Gbps/5Gbps/10Gbps plan: use XGS-PON ONR, 1 x 10G LAN port and 4 x 1G LAN ports. Take note these plans are all using XGS-PON ONR.
Strong points: very stable, may have some advantages in terms of routing to China.
Some users may want to go with the Entertainment bundles with Fibre Internet and Singtel TV / Singtel Cast.
https://www.singtel.com/personal/products-services/broadband/fibre-broadband-plans
https://www.singtel.com/personal/products-services/tv
2. Starhub (UltraSpeed 3Gbps/5Gbps/10Gbps, legacy 500Mbps/1Gbps/2Gbps plans)
Public IP, ONT, no vlan needed. With native dual stack IPv6 (/64 only)
Starhub legacy 2Gbps plan: ONT port 1 and ONT port 3 used to deliver 2x1Gbps connection, ONT port 2 for legacy Starhub Fibre TV.
Starhub UltraSpeed 3Gbps/5Gbps/10Gbps plan: using XGS-PON ONT now.
(Note: please check out the bundled router which may be subjected to change)
3Gbps --> ONT + HB410
5Gbps --> ONT + HB710
10Gbps --> ONT + EB810v or HB710
HomeHub+ 5Gbps/10Gbps plans --> ONT + HB710 or EB810v
Update on 27-Feb-2025: Starhub gets rid of the XGS-PON ONR based plans from public websites, but there may still be ONR based 5Gbps plan in the hidden links, or from 3rd party dealers. By now in Jan 2026 the Nokia XS-2426X-A ONR should be gone. Existing users of Nokia XS-2426X-A ONR can also request Starhub to replace the ONR with ONT.
Starhub HomeHub+ Plans: TV and Fibre Internet bundle:
https://www.starhub.com/personal/bundles/homehub-plus.html
3. M1 (3Gbps, 6Gbps and 10Gbps plans, legacy 500Mbps/2Gbps/1Gbps/2.5Gbps plan)
https://www.m1.com.sg/home-broadband
Public IPv4, ONT, no vlan needed. Native dual stack IPv6 (/64 only).
M1 legacy 2Gbps plan: ONT port 1 and ONT port 2 used to deliver 2x1Gbps connection.
Update on 8-Aug-2024: M1 replace M1 2Gbps plan with the true 2.5Gbps plan.
Update on 6-Sept-2024: M1 no longer offers 500Mbps plan to new users.
No more static IPv4 add-on as per reports.
Updated on 6-June-2025: M1 has a new 10Gbps plan which comes with all-in-one ONR (including WiFi 6). This is highly not recommended.
https://shop.m1.com.sg/fbb/plans-bundles/fbb-plan?plan=HOMEPAC_10GBPS_ONR_24
Updated on 1-Oct-2025: M1 has removed 1Gbps and 2.5Gbps plan.
4. MyRepublic (HyperSpeed and Gamer 10Gbps, legacy 3Gbps normal and gamer plans).
https://myrepublic.net/sg/broadband/
Using ONT
Carrier Grade NAT, no public IP by default. You can pay one time charge of S$51 for the Static IP.
No IPv6.
MR Gamer plans are perceived to have good speed and lower latency by some users. MR Gamer Plans may have the lowest latency to China.
MR 3Gbps/10Gbps plans are using XGS-PON ONT.
Updated on 11-Feb-2026: MR removed 3Gbps plans from the offerings.
5.Viewquest (10Gbps XGS-PON based plan with bridged ONR or XGS-PON ONU stick, 3Gbps plan).
Using CGNAT by default. You need to pay for static IP add-on to get public IPv4 address (monthly charges apply).
Free Working IPv6 upon request.
Recontract users may have options to upgrade to 3Gbps/10Gbps plan at reduced pricing.
VQ is also perceived by some users to have good performance. But some users have reported stability issues.
VQ 10Gbps plan:
https://viewqwest.com/sg/residential/broadband/
VQ 3Gbps plan:
https://viewqwest.com/sg/residential/broadband/3gbps/
6. Whizcomms (aggregated 2.5Gbps plan, 3Gbps/10Gbps plan), using Singtel Network
Public IP, no IPv6. ONR only.
Update: no ONR bridging request since 20-Dec-2023. Users have to take risks to do it by themselves.
WC 10Gbps plan (XGS-PON ONR)
https://whizcomms.com.sg/10gbps-broadband/
WC 3Gbps plan (XGS-PON ONR)
https://whizcomms.com.sg/3gbps-broadband/
WC 2.5Gbps plan (aggregated 2.5Gbps plan, GPON ONR)
https://whizcomms.com.sg/2-5gbps-broadband/
7. SIMBA (10Gbps plan, legacy 2.5Gbps plans)
https://simba.sg/broadband
10Gbps plan
Using XGS-PON ONT or ONR, CGNAT (no public IPv4 address), with IPv6, with digital voice.
Update o 7-July-2025, SIMBA starts to offer free Digital Voice.
Legacy 2.5Gbps plan (using GPON) users will be upgraded to 10Gbps plan.
8. Eight 10Gbps plan -- rolling out from 12 Nov 2025, now fully available in year 2026.
Using ONT, with dynamic IPv4, with IPv6.
https://www.eight.com.sg/
Updated on 06-March-2026
1. More about Digital voice
1) M1 digital voice is free with M1 Fibre Internet service. As per M1 Digital Voice terms and conditions, you can not de-bundle digital voice service.
https://www.m1.com.sg/terms-and-conditions/fixed-voice
2.1.M1 Fixed Voice Service (the "Service") is provided to you by M1 with the sign up of M1 High Speed Fibre Broadband Service for residential use at the service address only. Upon termination of M1 High Speed Fibre Broadband Service, the Service will also be terminated.
2) Stathub, you can not de-bundle digital voice service. Starhub digital voice is not free but at S$2.18 per month.
https://www.starhub.com/personal/home-phone/home-phone-line.html
++Fibre Broadband is a prerequisite for subscription to Digital Voice service.
3) Singtel -- Singtel digital voice is free with active Singtel Fibre Internet service.
Singtel also offers standalone Digital Voice at S$10 per month (6 month contract) but one time fee is high at S$214.14.
https://www.singtel.com/personal/products-services/more/telephony-services/home-digital-line
In fact Singtel still offers analog phone service.
https://www.singtel.com/personal/products-services/more/telephony-services/home-line
4) Porting Singtel digital voice to M1/Starhub.
The following post is for M1, but it is the same for Starhub. But take note Starhub digital voice is not free but at S$2.14 per month.
https://forums.hardwarezone.com.sg/...ussion-part-2.5658375/page-784#post-155687656
Sharing my recent experience with porting Singtel digital voice number to M1.
Do not call SIngtel to terminate your broadband (bundled with digital voice) until M1 notifies you that the port-in is successful. Singtel requires 7 days to terminate your broadband;
Failing to do so will require you to
  1. Call Singtel to "unterminate"
  2. Call M1 to proceed port in
  3. Wait for M1 to notify the successful port in
  4. Call Singtel to terminate (new effective date will be the date you call + 7 days)
5. SIMBA now has free digital voice service with the Fibre Internet service. And you can port digital voice service from other ISPs to SIMBA.
https://support.simba.sg/hc/en-us/a...ixed-line-number-from-other-service-providers
6. Whizcomms digital voice: S$3.04 per month, no contract. Port-in is free.
https://whizcomms.com.sg/home-digital-line/
Update on 06-March-2026: Whizcomms 3Gbps/10Gbps plan come with free digital voice now.
7. MyRepublic Home Voice: free with fibre internet service
https://myrepublic.net/sg/add-ons/home-voice/
Port-in is not free, with one-time charge.
https://support.myrepublic.net/en/a...r-port-in-my-existing-home-line-to-myrepublic
8. Viewquest OneVoice at S$4.03 per month. It is not possible to port-in from other ISPs.
https://viewqwest.com/sg/residential/onevoice/
2. More about GPON limitation and XGS-PON limitation
GPON: Theoretical max speed: 2.5 Gbit/s download, 1.25 Gbit/s upload. This applies to 2.5Gbps plans from M1/SIMBA/WC (total bandwidth). ST/SH/M1/MR/VQ 2Gbps plan --> 2Gbps download and 1.25Gbpr or 1Gbps upload (total bandwidth).
XGS-PON: the 10Gbps plans with XGS-PON technology will be limited to be about 8.2Gbps download/upload in general.
As of 1-Nov-2025, only Singtel 2Gbps plan and WC 2.5Gbps plan still use GPON ONR. Other new plans all use XGS-PON ONT/ONR.
3. More about Singtel as an home Fibre ISP
Singtel is the No 1 consumer ISP here in Singapore, followed by Starhub+MR (Starhub now owns 100% of MR Fibre Broadband), and then followed by M1 (SIMBA has a proposal to acquire M1 Fibre Broadband business now).
Singtel is also the most stable consumer ISP in Singapore if you use downtime as the reference.
Why I do not recommend Singtel for new users and power users?
There are a few known limitation of Singtel Fibre Internet in general. The use of ONR is No 1 issue to me.
1) Use of unbridged ONR for 2Gbps plans and above (all users). Singtel ONR will be the main router of the network yet it has very basic features (you can not even set up your own DNS servers). It may not be able to handle many clients. And there are reports that user may face certain port forwarding issues.
For Singtel 3Gbps/5Gbps/10Gbps plan. It will come with ZTE or Nokia XGS-PON ONR not bridged by default.
Singtel charges S$10 per month to bridge the XGS-PON ONR. The users may be able to bridge the ONR at their own risks. YMMV.
Update on 1-Nov-2025, Singtel stops the service for official XGS-PON ONR bridging.
2) International routing issue to quite some locations. On the other hand, it may be the better one among local ISPs for the connection to China (MR Gamer Plan is probably the best). So it depends on your use case.
Reference: "Other ISPs peer openly at SGIX whereas SingTel will only selectively peer with others".
https://forums.hardwarezone.com.sg/...ame-server-is-st-routing-to-the-moon.6942466/
Reference: Singtel is the better ISP if you use Taobao heavily.
https://forums.hardwarezone.com.sg/threads/best-isp-for-taobao.6933181/
Reference: Singtel is not bad for China.
https://forums.hardwarezone.com.sg/threads/china-content-lover-lip-lai.7044620/
Reference: Fastest ISP thread. M1 and SIMBA may not be good for China contents.
https://forums.hardwarezone.com.sg/threads/fastest-isp.6996674/page-3
3) SingTel is known to throttle certain traiffic like Torrent. You can use client like qBitTorrent and force encryption to get better download speed though. But for ONR users, the ONR can be another limiting factor as well.
Updated on 24-Nov-2025: Singtel changes its stance on this topic.
https://www.singtel.com/personal/support/broadband/typical-download-speeds
No, Singtel does not throttle or apply traffic shaping on any of its Fibre Broadband Plans.
4) Singtel usually gives the worst free wireless router or AP (mesh node) compared to other ISPs.
Singtel 5Gbps/10Gbps plan users have the option to go with TP-Link HB810, which is a decent 10Gbps capable WiFi 7 router. But they may also provide HB611-SGST for 5Gbps/10Gbps plans but HB611-SGST is only capable of 2.5Gbps.
5) Singtel promotes its own mesh solution from Arcadyan and Askey. They are not good mesh solutions and only capable of 1Gbps. This is no longer the case with XGS-PON based SIngtel 3Gbps/5Gbps/10Gbps plans since they switch to TP-Link HB611-SGST/HB810.
6) Singtel started to deploy native IPv6 service in late 2023, with /56 prefix. But ONR users may not be configured with native IPv6 by default.
7) Many power users have left Singtel because of the above issues, especially because of ONR. I also do not recommend new users to go with Singtel also because of the ONR. Even though average users may not have issues with ONR but that may limit the flexibility and freedom of using one's own router to the full of its capability. More over, Singtel typically charges higher cost for the Fibre internet plans.
8) Take note Singtel no longer offers recontract of ONT based legacy plans as per the reports on 12-Dec-2024, In this case, people who want to keep using ONT plus their own router may have to leave Singtel and go with other ISPs offering ONT like M1/Starhub.
9) That being said, most of the average existing Singtel users should have no issues with Singtel ONR. In that case, there is no issue to stick to Singtel because of the stability. I will still recommend to move away from Singtel specific wireless router and mesh solution (Askey and Arcadyan) in this case.
4. More about SIMBA as an ISP.
Main issues now for SIMBA, at least from the reports, are the following
1) Lack of support --> this can be a critical issue especially for average users who are not tech savvy
2) CGNAT without Static IPv4 add-on. SIMBA 10Gbps has native IPv6 which may help but it may still be an issue for those want to have a public IPv4 address. You can refer to the earlier discussion about CGNAT in this post.
3) There are some routing issues reported as well.
#2 (lack of support) is the main reason that I can not recommend SIMBA to average users as of now.
Power users know their use cases well -- so it is usually not an issue to go with their choice of ISPs. But I would not recommend power users to go for SIMBA either because of #2 (CGNAT without static IPv4 add-on).
5. More about using VQ as an ISP
Some power users may want to consider VQ due to some power user friendly features, like Static IPv4 add-on, SFP+ ONU, free static IPv6 and better performance to some locations. On the other hand, there seems to be frequent report of stability issues by some users. For average users, it is probably better to go with M1/Starhub.
If you use dual ISP, no problem with using VQ as one of the ISPs.
News: May 2025, ViewQwest being probed by regulator over week-long service disruption
https://www.straitstimes.com/singap...y-regulator-over-week-long-service-disruption
Latest disruption on 11-Oct-2025.
https://forums.hardwarezone.com.sg/...dband-official-thread-part-6.6473287/page-153
BTW, MR and Starhub had some stability issues as well in 2024, during migration to XGS-PON based plans. Now the issues seem to be gone.
Updated on 16-March-2026
The following is a quick summary about the consumer Fibre Internet plans offered by local ISPs to (mainly new) users.
Take note existing users may be able to recontract with legacy plans. You may also check with your ISP for exclusive recontract offer.
Most of the plans come with 24 months contract. Exceptions are listed below.
1) Whizcomms offer 12 month contract 2.5Gbps and 10Gbps plan
2) SIMBA offers 12 month contract 10Gbps plan.
3) eight offers 12 momth 10Gbps plan.
4) MyRepublic offers no contract 10Gbps plan.
https://myrepublic.net/sg/no-contract-10gbps-broadband/
1. SH: Fibre broadband only -- only 3Gbps/5Gbps/10Gbps plans for new users.
https://www.starhub.com/personal/store/broadband.html
https://www.starhub.com/personal/bundles/homehub-plus/ultraspeed.html
Starhub new home offer: 3Gbps
https://www.starhub.com/personal/forms/hubbing/new-homeowners.html
3Gbps with free HB410 at S$29.55 per month
5Gbps with free HB710 at S$29.55 per month​
10Gbps with free WiFi 7 router at S$48.40 per month (need to confirm whether it is HB710 or EB810v).​
Starhub CIS offer (only for CIS eligible customers): 10Gbps at S$33.59 per month with free HB710.
https://www.starhub.com/personal/broadband/cis.html
Some users also get the above S$33.59 10Gbps offer without CIS.
Some existing users may even get S$30.49 per month 10Gbps recontract offer with ONT plus free HB710.
Starhub 3Gbps offer with ONT+HB410.
https://www.starhub.com/personal/forms/hubbing/3gbps-broadband-exclusive.html
Direct link of the above 3Gbps offer:
https://www.starhub.com/personal/st...speed-3gbps-ont-at-2955_ultraspeed-3gbps.html
Starhub Passion Card Offer
https://www.starhub.com/personal/promotions/passioncard.html#broadband
3Gbps Broadband Plan at $29.55/mth (U.P. $58.83)
1 Free TP-Link HB410 WiFi 7 router
worth $549
$50 free shopping vouchers
Starhub offer for new users -- you need to contact Selina using WhatsApp at 81161630. Existing users may also sign up as a new user but the digital voice number may need to change if you have digital voice.
5Gbps Broadband @$29.55/mth
- 1x Free TP-Link HB710 WiFi 7 router
- Free $100 Shopping Vouchers -- upgraded to S$150 vouchers.
10Gbps Broadband @$44.49/mth
-1x Free TP-Link EB810v WiFi 7 router
- Free $250 Shopping Vouchers
10Gbps Broadband @$33.59/mth
-1x Free TP-Link HB710 WiFi 7 router
-No Voucher
Installation and activation fess waived
*24 months contract
2. Singtel: 2Gbps and 3Gbps/5Gbps/10Gbps plans for new users.
Take note Singtel keeps changing the offer contents.
FIBRE BROADBAND PROMOTIONS TERMS & CONDITIONS -- this will keep changing.
https://www.singtel.com/content/dam/singtel/eshop/Fibre/agreements/singtel-fibre-broadband-tncs.pdf
1) Normal web links and some hidden web promotion links.
2) Special new user offer
3Gbps offer at S$29.90 per month, for targeted new Singtel Fibre Internet users, usually with Singtel mobile postpaid plan only.
Updated on 12-March-2026
https://www.singtel.com/personal/products-services/mobile/eform/sweetch/ekyc
3) New Home Offer
https://www.singtel.com/personal/products-services/broadband/eform/newhomes
https://www.singtel.com/content/dam...greements/singtel-fibre-newhomes-atl-tncs.pdf (new home offer)
3Gbps Enhanced (WiFi 7) Plan at $29.90/mth (U.P. $55.90/mth)
Plan comes with:
1 unit of Singtel WiFi 7 Tri-band router (HB611)
3Gbps Mesh (WiFi 7) Plan at $38.70/mth (U.P. $73.90/mth)
Plan comes with:
2 units of Singtel WiFi 7 Tri-band routers (HB611)
5Gbps Enhanced Mesh (WiFi 7) at $49.70/mth (U.P. $88.90/mth)
Plan comes with:
https://www.singtel.com/personal/products-services/broadband/eform/newbb (new user offer)
4) Other offers
https://www.singtel.com/personal/products-services/broadband/eform/3gbps-plan (3Gbps offer)
https://www.singtel.com/personal/products-services/broadband/eform/5gbps (5Gbps offer)
https://www.singtel.com/personal/products-services/broadband/eform/10gbps (10Gbps offer)
https://www.singtel.com/personal/products-services/lifestyle-services/ntuc (Singtel NTUC offer)
5) Other niche plans
https://www.singtel.com/personal/pr...and/fibre-broadband-plans/fibre-gaming-bundle
(Singtel 5Gbps Gamer Pro Bundle and 10Gbps Gamer bundle) --> not pro at all as it uses unbridged ONR.
https://www.singtel.com/personal/products-services/broadband/fibre-everywhere-fttr (Singtel FTTR, niche plan)
https://www.singtel.com/personal/products-services/broadband/homepriority (Home Priority, niche plan)
Now only Singtel 2Gbps plan with lousy Singtel AX5400 mesh solution (4 nodes) available.
6) Singtel recontract offer for 3Gbps/5Gbps/10Gbps
Please refer to Post #10 as well for more offers.
Singtel 3Gbps recontract offer
There may be another targeted recontract offer for existing users at S$39.90 per month but with free two TP-Link HB611-SGST WiFi 7 router (no links, you have to negotiate with Singtel if they have not given you the offer).
Singtel 5Gbps recontract offer
https://www.singtel.com/personal/products-services/broadband/eform/recon-edm/5gbps-plan
5Gbps Enhanced Plan at $29.90/mth (U.P. $70.90/mth)
Comes with 1 x Singtel WiFi 7 (TP-Link BE11000) Router
Singtel 10Gbps recontract offers
a) Singtel 10Gbps recontract offer 1
https://www.singtel.com/personal/products-services/broadband/eform/recon-dm/fibre-10g
10Gbps Mesh (WiFi 7) Plan at $59.70/mth (U.P. $107.90/mth) + FREE $150 FairPrice Shopping Voucher
Comes with 2 units of Singtel WiFi 7 Mesh Routers (1 x BE11000 and 1 x BE22000)
b) Singtel 10Gbps recontract offer 2
https://www.singtel.com/personal/products-services/broadband/eform/recon-edm/10gbps-plan
10Gbps (WiFi 7) Mesh Plan at $65/mth (U.P. $139/mth)
Comes with 1 x Singtel TP-Link WiFi 7 BE11000 Router
3. M1 now only have XGS-PON based 3Gbps/6Gbps/10Gbs based plans.
https://www.m1.com.sg/home-broadband/plans
M1 promotions, terms and conditions
https://www.m1.com.sg/terms-and-conditions/fibre-broadband-promotions
M1 Chinese New Year offer for 10Gbps plan without router: S$30.90 per month for new users. Available from M1 Physical Stores.
Updated on 6-March-2026: M1 has S$29.90 per month10Gbps ONT plan without router limited time offer for new users. Available from M1 Physical Stores.
10Gbps Integrated ONR plan is also on offer at S$30.90 per month.
Take note M1 keeps increasing the price of 6Gbps plan from S$34.90 per month in Jan 2025 to S$38.90 per month in Nov 2025. Recontract offer increases from S$32.90 per month to higher price like S$36.90 per month as well (check with M1 for your recontract offer).
Some M1 users may get S$29.50 per month 3Gbps recontract offer.
Update on 1-Oct-2025 --> M1 has removed 1Gbps and 2.5Gbps plan.
Existing M1 users are able to pay subsidized price for better routers like Asus ZenWiFi BT10 twin-pack (PWP offer at S$504 for the twin-pack, very good offer) and TP-Link Archer BE805 (S$360).
Updated on 6-June-2025: M1 has a new 10Gbps plan which comes with all-in-one ONR (including WiFi 6). Personally I do not recommend this plan, better to go with ONT based plan.
4. MR -- 10Gbps normal plan and 10Gbps Gamer plan.
MR offers no-frills plan or plans with different router bundles.
If you are wiling to pay, they have the 10Gbps Gamer Plan bundle with Asus ROG GT-BE25000 (same as ROG GT-BE98).
5. VQ -- XGS-PON based 3Gbps/10Gbps plan, including XGS-PON ONU Stick based option for power users.
For new users, VQ may also have special limited duration offer for 3Gbps/10Gbps plan as well.
6. Whizcomms -- 2.5Gbps plan at S$26 per month; 3Gbps plan at S$26 per month, 10Gbps plan at S$26/S$28.80/S$28.99/S$29.99 per month.
For new users, $59.95 WhizComms Installation Fee and $61.04 NetLink Trust Activation Fee apply for Whizcomms 2.5Gbps plan. Therefore it is better to go with 3Gbps or 10Gbps plan.
7. SIMBA -- 10Gbps plan at S$29.99 per 30 days.
8. eight Home Internet: rolling out sign-ups from 12 Nov 2025, with priority to eight 5G customers. Now it is open to all customers.
https://www.eight.com.sg/home-internet
9. Low income family may want to check this government scheme here, as low as S$5 per month for M1 500Mbps plan.
https://www.imda.gov.sg/how-we-can-help/digital-access-at-home
Updated: 10-March-2026
Some notes
1. It is good to have more competitions with around S$30 per month (effective pricing) plans from the ISPs.
You may want read Post #3 for more up-to-date information about lower cost plans.
I tend to recommend either Starhub or M1 for new users.
2. Static IPv4
MR/VQ have static IPv4 add-on. Advice from Brother TanKianW.
https://forums.hardwarezone.com.sg/...ussion-part-2.5658375/page-519#post-146905946
M1 stopped offering Static IPv4 add-on to new users in 2024.
3. Issue with CGNAT (MR, VQ and SIMBA) and workarounds
https://forums.hardwarezone.com.sg/threads/myrepublic-fibre-part-5.4981088/page-340#post-149246011
Majority of users will be okay with CGNAT but some users get affected (eg: cannot do port forwarding or hosting services).
VQ/MR provide static IPv4 add-on for those who hit the limit of CGNAT.
Unfortunately SIMBA does not have that add-on. It provides public IPv6 for 10Gbps plan users as a potential work-around but not able to sort out all issues.
https://en.wikipedia.org/wiki/Carrier-grade_NAT
  • Carrier-grade NAT usually prevents the ISP customers from using port forwarding, because the network address translation (NAT) is usually implemented by mapping ports of the NAT devices in the network to other ports in the external interface. This is done so the router will be able to map the responses to the correct device; in carrier-grade NAT networks, even though the router at the consumer end might be configured for port forwarding, the "master router" of the ISP, which runs the CGN, will block this port forwarding because the actual port would not be the port configured by the consumer.[7] In order to overcome the former disadvantage, the Port Control Protocol (PCP) has been standardized in the RFC 6887.
  • In cases of banning traffic based on IP addresses, a system might block the traffic of a spamming user by banning the user's IP address. If that user happens to be behind carrier-grade NAT, other users sharing the same public address with the spammer will be inadvertently blocked.[7] This can create problems for forum and wiki administrators attempting to address disruptive actions of a single malicious user sharing an IP address with legitimate users.
4. ONT vs ONR
Please refer to the following post.
https://forums.hardwarezone.com.sg/...cs-of-home-networking.6653421/#post-138363236
Take note that there are no more dual 1Gbps plans like M1 2Gbps, Starhub 2Gbps, MR 2Gbps and Singel 1+1 Gamer Bundle, for new users.
All the ISPs' 3Gbps/5Gbps/6Gbps/10Gbps plans (all based on XGS-PON technology) are single 3Gbps/5Gbps/6Gbps/10Gbps plan.
For those 3Gbps/5Gbps/6Gbps/10Gbps plans using XGS-PON ONT, only one 10G port of the ONT is active.
For those 3Gbps/5Gbps/6Gbps/10Gbps using XGS-PON ONR, then one 10G port and a few 1G ports of the ONR are active.
Power users will usually avoid ONR due to the limitations of the ONR (usually with slow CPU and limited FW features). Some average users may actually like ONR as it saves one router in the DB box and ONR has a few LAN ports functional.
5. International routing (which may affect gaming and some other things).
Singtel is said to have not so good routing to many international locations, which may affect gaming performance. On the other hand, it is actually the better ISP to go for China, whereas M1 and SIMBA are known to have not-so-good routing to China.
https://forums.hardwarezone.com.sg/...ame-server-is-st-routing-to-the-moon.6942466/https://forums.hardwarezone.com.sg/threads/best-isp-for-taobao.6933181/
7. Good point from @Mach3.2 here.
https://forums.hardwarezone.com.sg/...ussion-part-2.5658375/page-597#post-153037580
There's more nuance to how a connection is considered good. connection speed is largely meaningless for most people, and is just a convenient number ISPs like to use to differentiate their services in the market.
the real metric that really matters is how well peered they are, and how much upstream capacity they have relative to their user base, and the quality of their upstream transit providers.
And guess what? this aspect isn't transparent, so good luck to you unless you put in effort to figure it out.
1. Why it is difficult for local consumer ISPs to offer S$20 per month (with GST) Fibre Internet plans?
This is because NLT charges the ISPs at S$13.50 per user per month (1:24 split ratio). Therefore it is difficult for any ISPs to offer S$20 per month to happen from Singtel/M1/Starhub unless NLT reduces the price further. The lowest per month pricing previously was S$21.80 for WC/SIMBA 2.5Gbps plan but both have raised price (without wireless router bundle).
NLT charges --> S$15 per month per user initially.
https://www.imda.gov.sg/-/media/imd...network/netlink-trusts-ico/19-schedule-15.pdf
Reduced to S$13.80 per month per user based on the following IMDA file dated 2-March-2020.
https://www.imda.gov.sg/-/media/imd...work/schedule-15-approved-date-2-mar-2020.pdf
Furher reduced to S$13.50 from April 2024 onwards as per the following DBS article.
https://www.dbs.com.sg/treasures/ai...t/data/en/DBSV/052024/NETLINK_SP_05202024.xml
2. Just some history here about pricing.
https://www.hardwarezone.com.sg/feature-why-fibre-broadband-is-so-fast-singapore
https://www.tech.gov.sg/media/technews/history-of-the-internet/
Fibre internet service
1) 2010: 25Mbps/50Mbps/100Mbps/1Gbps plans, M1 1Gbps is at S$399 per month.
https://www.hardwarezone.com.sg/tec...ces-new-broadband-plans-new-national-fibre-ne
https://corporate.starhub.com/about...omebroadbandplansfornextgenerationnation.html
2) 2013-->2014, rapid price drop of 1Gbps services. I actually did not know that Singtel was a late comer to 1Gbps plan. MR was the disrupter then.
https://www.hardwarezone.com.sg/feature-overview-fastest-fiber-broadband-plans-singapore
3) 2016 --> 10Gbps plan launched by SIngtel/M1/VQ/SI with much lower price than when 1Gbps plans were launched in 2010. It was probably ahead of its time so only Singtel kept the 10Gbps plan until Starhub launched 10Gbps in 2023.
10Gbps plan Launch price --> Singtel/M1 at S$189 per month, SI at S$199 per month, VQ 10Gbps plan at S$218 per month.
https://www.hardwarezone.com.sg/tec...ngtels-crazy-fast-10gbps-fiber-broadband-plan
https://www.hardwarezone.com.sg/tech-news-now-you-can-sign-m1s-10gbps-fiber-broadband-plan-your-home
https://www.hardwarezone.com.sg/fea...s-end-end-10gbps-home-fiber-broadband-service
4) late 2023/2024/2025 --> rapid drop of 10Gbps/6Gbps/5Gbps plan pricing.
Old info consolidated.
1. Summary for the year 2022 (update in Dec 2021):
My recommendation for new users is to go with M1 or Starhub, either 500Mbps plan or 1Gbps plan. Both of them are using ONT and have proper IPv6 implementations.
As for exisitng users, if it an't broke, then no need to change. If you want to change due to issues, then that is okay -- you can consider M1 or Starhub.
And usually many users are facing Wifi issues due to poor ISP bundled free router, or poor placement of the router. Wifi issues will not be sorted out by upgrading to 2Gbps plan, or by switching ISPs. You need to get better routers and/or optimize the router placement, or add more APs.
A point to note is that it may not be a good idea to switch to a different ISP due to the "better" free bundled router.
As for switching because of better promotions, please also consider the NLT charges and the extra charges. Do you maths first.
2. Impressions of ISPs in 2021 based on my reading in this forum. YMMV.
1) Best in terms of stability: most of ISPs are okay, except Viewquest
2) Fastest: all ISPs are okay, staticsticks may still show Viewquest and MyRepulic are the fastest, however, this is more likely due to the user base (more power users)
3) Best in terms of offer for new users and recontract users: Starhub
4) Good latency: Viewquest and MyRepublic, then M1/Starhub, but sometimes it also depends (eg: gaming server locations). Wost will be Whizcomms because it uses Singtel network, and Singtel will de-priotize Whizcomms customers in terms of routing compared to Singtel customers.
5) Good IPv6 support: M1 and Starhub
6) No or almost no throttling of BT traffic: Viewquest and Myrepublic.
7) Best valus ISP plans: 500Mbps plan from M1 and Starhub
8) Fastest ISP Plan: SuperInternet 10Gbps plan, only for niche users. [No longer offered to consumers]. The only consumer 10Gbps plan being offered now is from Singtel now (using Singtel 10G ONR with one 10G port and a 4 x 1Gbps port), XG-PON technology with 10Gbps download and 2.5Gbps upload.
Overall Best ISPs: it depends on each individual. But for new users, I will recommend M1 and Starhub.
badsector
and those interested in Geforce Now. it's powered by Starhub only.
not sure how's the latency from other ISP
bert64
Overall Best ISPs: it depends on each individual. But for new users, still I will recommend M1 and Starhub.
From what i read here a few weeks ago, SI also offer a 1gbps plan (although its around $60 so still more expensive than the others) and have good IPv6 support, but it's not well advertised and you have to call them.
Their 10gbps is also symmetric which noone else seems to be offering.
Updated on 10-March-2026
1. Please read Post #3 and Post #5 to see which plan you like to go. Usually I will recommend M1/Starhub for new users. But you may decide on the best plan you want to go.
I do not include short time promotion offers (eg: from VQ) so you may want to check out the individual ISP thread to check out.
For new users, I will usually recommend Starhub and M1. But I understand people may have good reasons to go with other plans.
For example, M1 may not be a good choice if you are heavy on China contents.
Starhub customer service may not be the best and Starhub Digital Voice is slow.
In general I do not recommend SIMBA due to the fact that it does not have good support for average users and it uses CGNAT which is not good for power users.
MR and VQ also use CGNAT, but power users can subscribe to static IPv4 add-on. VQ users may have some stability issues from time to time but the reports seem to indicate that users with static IPv4 add-on and not using FreeDom DNS may have better stability. After the merger with Starhub, there are also some complaints about MR. Please check out VQ and MR thread if you are interested in these two ISPs.
WC and Singtel use ONR. So they are not good for power users who want to use their own router to its full potential (no Double NAT, not using the powerful router in bridge mode and waste the CPU power). That being said, for average users who do not mind ONR, WC can be a good option as a low cost yet stable ISP. SingTel is arguably the most stable ISP and the support is better than WC. So it can be a good option as well for average users who prefer to go with SingTel due to the stability.
2. Best offer from Starhub: offer history since late 2024
Starhub 5Gbps special offer history from late last year.
Note: many existing Starhub signed up as new users to get the S$29.55 per month offer.
Note: for recontract, there is no online link.
1) Nokia ONR + Nokia Beacon 2 at S$29.55 per month, new user offer
2) Nokia ONT without router at S$29.55 per month, new user offer
3) Nokia ONR + Nokia Beacon 2 at S$30.37 per month, for recontract only
4) Nokia ONT with EX510 router at S$30.37 per month, for recontract only
Best offers earlier this year -- seem to be no more but somehow there are users who managed to get the offer even now in the end of June 2025.
5) Nokia ONT with HB710 router at S$29.55 per month, new user offer
This is a very good offer, but the original online link now redirects to the 3Gbps ONT + HB410 offer.
https://www.starhub.com/personal/st...speed-5gbps-ont-at-2955_ultraspeed-5gbps.html
6) Nokia ONT with HB710 router at at S$30.37 per month, for recontract only
Current offers -- 3Gbps ONT offer
7) Nokia ONT with HB410 router at S$29.55 per month
8) Best recontract offer now -- S$30.49 for 10Gbps plan with free HB710. You may have to negotiate with Starhub to get this offer.
9) Best new user offer now:
a) Passion Card offer for Starhub 3Gbps
worth $549
b) CIS new user offer for 10Gbps at S$33.59 per month with free HB710. This is only for Starhub Mobile CIS customers who want to sign up a new Starhub Fibre Broadband line.
c) Non-CIS new user offer for 10Gbps at S$33.59 per month with free HB710. This may be a targeted offer for some customers like Starhub giga mobile customers.
d) Good offers reported in Jan 2026 and still valid in Mar 2026. Please contact the famous Selina in this forum to check out the offer, using her WhatsApp at 81161630.
-No Voucher
*24 months contract
3. Best offer from M1 since 2025
1) 6Gbps targeted recontract offer with ONT + TP-Link Archer BE805 or Asus RT-BE92U, or top up S$12 for a pair of Asus ZenWiFi BT10, S$32.90 per month. This price was valid in early 2025. Later the price has increased to S$34.90 per month and S$36.90 per month. Now the recontract price may be at S$38.90 per month or higher.
The offers as of 13-Oct-2025 are worse than previously. The offers as of 19-Nov-2025 is even worse for 6Gbps as M1 keeps raising the price of 6Gbps plan in year 2025.
That being said, some existing M1 users may still get some discount for 3Gbps plan, for example, S$3.4 discount to get 3Gbps recontract offer at S#29.50 per month.
2) Online offer for new users: 6Gbps new home offer with ONT + TP-Link Archer BE805 or Asus RT-BE92U, or top up S$12 for a pair of Asus ZenWiFi BT10, S$38.90 per month. You may go to M1 Shop and get S$36.90 per month pricing instead -- now at S$40.90 per month.
3) 3Gbps online offer at S$32.90 per month: ONT+ free Archer BE230 or Asus RT-BE58U, for both new users and recontract. It was lower at S$29.50 per month previously.
4) M1 10Gbps at S$34.90 per month without router, for recontract. This may be a good offer for those who want to use their own router.
M1 10 Gbps new user offer at S$30.90 per month without router. This may be a good offer for those who want to use their own router.
Update on 10-Jan-2026 --> the 10Gbps at S$30.90 Christmas offer ended. Now the new user offer is at S$34.90 per month.
Update on 13-Feb-2026 --> Chinese New Year offer started and the 10Gbps S$30.90 offer is back. It is still valid as of 5-March-2026 as per the poster at M1 Jurong Poont Shop.
Updated on 6-March-2026 --> M1 10Gbps S$29.90 offer at M1 physical shop.
5) Take note I do not recommend M1 10Gbps ONR plan. Somtimes it may have offer at S$34.90 or even S$30.90 per month.
1. Specific to Singtel TV users
1) Singtel ONT user -- VLAN capable router or switch required. Only for legacy 500Mbps/1Gbps customers.
https://forums.hardwarezone.com.sg/...properly-singtel-asus-rt-ax86u.6564040/page-3
https://forums.hardwarezone.com.sg/threads/singtel-tv-compatible-wi-fi-mesh.6664236/#post-138751490
2) Singtel ONR users with Singtel TV boxes (unbridged)
So far only SIngtel issued router or Netgear Orbi can work with Singtel TV box when running in AP mode after the Singtel ONR (unbridged). There is another way of using IGMP capable router in special AP mode.
https://forums.hardwarezone.com.sg/threads/singtel-onr-ap-issues.5778791/page-3https://forums.hardwarezone.com.sg/...tel-tv-onr-ac86u-ax23-singtel-tv-box.6681949/
3) Singtel ONR users with Singtel TV boxes (bridged)
If you bridge the ONR, the Singtel TV Set-top boxes must be connected to the unbriged Port. Same for the new Android TV OS based Singtel TV boxes.
4) For those who want to use SingTel TV box without SingTel Fibre Broadband plan, it is possible to do that. SingTel will issue you an ONR to connect your SingTel TV box to. Take note the SingTel ONR will need to occupy one Fibre Terminal Port.
5) It is now possible to use SingTel Cast app to access SingTel TV contents on supported devices (eg: Android TV, Apple TV, Samsung TV) without using SingTel TV box and without the needs of SingTel Fibre broadband plan.
SingTel Cast Viewing Tips
https://www.singtel.com/personal/products-services/lifestyle-services/cast/viewingtips
2. Specific to Starhub TV+ users
1) Application of using VLAN switch to mix Starhub Fibre TV and Fibre Internet, for legacy Fibre TV box
https://forums.hardwarezone.com.sg/threads/starhub-iptv-in-switched-network-help.5143406/page-4
2) Potential solution of using VLAN switch for Starhub TV+ box and Mediacorp FTA channels (but it is easier to use meWatch app): post #136 -- no longer needed
https://forums.hardwarezone.com.sg/threads/network-dilemma-on-starhub-tv.6380041/page-7
Update on Sept 2023: it is no longer necessary to use Starhub issued router for MediaCorp FTA channels on the Starhub TV+ box or Starhub TV+ Pro box.
3) in fact you do not need even Starhub Fibre Internet access to use Starhub TV+ box or Starhub TV+ Pro box.
Starhub TV+ Box FAQ
https://www.starhub.com/personal/support/article.html?id=Hj05icItvfAnYFyM5ODw38
Starhub TV+ Pro Box FAQ
https://www.starhub.com/personal/support/article.html?id=SCyXQTiTtbAMznCs3D9CjA
4) You can also use Starhub TV+ app with some Smart TVs, using Android TV OS based Android TV or Android TV Box and Samsung Smart TV.
StarHub TV+ Smart TV FAQ
https://www.starhub.com/personal/support/article.html?id=q4cO03FeAO3lTpZkhhREd8
Updated on 10-Jan-2026
1. Options for existing Singtel users (recontract)
If you are fine with your Singtel Fibre internet plan, there is no problem to stay with Singtel, even though I do not recommend new users to go with Singtel.
ONT users who are using their own router and want to keep using the Singtel ONT: unfortunately, as per the report on 10-Dec-2024, Singtel has stopped to offer recontract of ONT based legacy plans. You have to prepare to leave SIngtel for other ISPs using ONT.
Singtel now offer bridging of XGS-PON ONR for S$10 per month.
Update on 1-Nov-2025: Singtel no longer offers ONR bridging service. They have changed the terms and conditions to mention the following.
A few Singtel users were able to negotiate with Singtel to get official Singtel ONR bridging for free. YMMV.
Quite a few other users (including myself) choose to carry out bridging manually. Proceed at your own risk. YMMV.
Good Singtel recontract offer now (as of 10-Jan-2026).
1) Singtel 3Gbps plan at about S$39.90 per month with two HB611-SGST.
Some users may get this offer from Singtel directly (targeted offer). If not, you need to negotiate with Singtel to get the offer.
The other offer for 3Gbps recontract offer is at S$39.90 per month but with S$120 or S$240 voucher.
I am not so sure if the following user manages to get so high voucher. Usually the voucher amount is much less at about S$120.
so my 1gbps plan expired this month..it reverted back to the no contract $40++ rate.
Right on schedule I received a mailer from Singtel on their 3gbps enhanced plan at $39.90/mth (24 mth contract), which includes:
- 1 x TP-Link HB611 Router
- $240 Fairprice Vouchers
- 12 months of Amazon Prime etc
leaning towards renewing (essentially, can it be viewed that the vouchers offset the monthly payment, reducing it to $29.90/mth??)..but then sometimes I think about the lousy singtel service i have to deal with..
2) Singtel 5Gbps recontract offer at S$29.90 per month with free HB611-SGST.
2. Options for new users who want to go with Singtel for its stability and do not mind using Singtel ONR: Singtel 3Gbps plan (this offer is mostly for targeted new users with existing Singtel Mobile postpaid services)
If this offer is not available, there may be another offer for 3Gbps at S$39.90 per month with free HB611-SGST.
https://www.singtel.com/personal/products-services/broadband/eform/5gbps-10gbps-addons-tv
3) New Home Offer #1 --> not so sure if this offer is still valid or not.
https://www.singtel.com/personal/products-services/broadband/new-homes/singtel-fibre
5Gbps at S$29.90/mth with 1 x Singtel WiFi 7 router (HB611-SGST, Tri-band BE11000)
5Gbps mesh at S$34.70/mth with 2 x Singtel WiFi 7 router (HB611-SGST, Tri-band BE11000)
10Gbps at S$45.90/mth with 1 x Singtel WiFi 7 router (HB810, Tri-band BE22000)
New Home Offer #2
3Gbps Mesh (WiFi 7) Plan at $38.70/mth (U.P. $73.90/mth) with two HB710.
Please check the link for more offers.
4) New User Offer
Please refer to Post #3 for other Singtel offers.
3. Singtel issued routers and mesh solution
https://www.singtel.com/personal/support/broadband/routers-ont
10G capable ONR (wired)
10G capable triband BE22000 WiFi 7 router -- TP-Link HB810
You can buy HB810 from Singtel at S$16.80 per month x 24 = S$403.2.
https://www.singtel.com/personal/products-services/broadband/eform/wifi7
2.5G capable triand BE11000 WiFi 7 router -- Singtel/TP-Link HB611-SGST
4. Security update duration of Singtel issued routers.
You should change your router if Singtel no longer provides security updates.
https://www.singtel.com/personal/support/broadband/troubleshoot-by-router
Singtel now only provides HB611-SGST (3Gbps/5Gbps/10Gbps plans) and HB810 (selected 10Gbps plan) for the XGS-PON based plans. Exceptions will be Singtel FTTR plan (Huawei equipment) and Singtel Home Priority 2Gbps plan (Singtel WiFi 6 Mesh Device, probably AP5690W)
5. FW updates of Singtel issued router:
Either through MySingTel app or through manual download from Singtel website.
https://www.singtel.com/personal/support/broadband/how-to-download-latest-firmware
firesong
Deluxe Member
[TH]SingTel[/TH]
[TH]
StarHub​
[/TH]
[TH]
M1​
[/TH]
[TH]
MyRepublic​
[/TH]
[TH]
ViewQwest​
[/TH]
[TH]
Whizzcomms​
[/TH]
[TH]
SIMBA​
[/TH]
[TR]
[TH]500Mbps[/TH]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TH]1Gbps[/TH]
[TD]
[/TD]
[TD]
[/TD]
[TD]
$35.90​
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TH]2Gbps[/TH]
[TD]$43.90[/TD]
[TD]$39.00[/TD]
[TD]-[/TD]
[TD]-[/TD]
[TD]-[/TD]
[TD]-[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TH]2.5Gbps[/TH]
[TD]-[/TD]
[TD]-[/TD]
[TD]$39.90[/TD]
[TD]-[/TD]
[TD]-[/TD]
[TD]S$24.00/month (24 months)
S$26.00/month (12 months)[/TD]
[TD]S$29.99/month
(12 months)[/TD]
[/TR]
[TR]
[TH]3Gbps[/TH]
[TD]-[/TD]
[TD]-[/TD]
[TD]$40.90[/TD]
[TD]$37.99[/TD]
[TD]-[/TD]
[TD]-[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TH]5Gbps[/TH]
[TD]$55.09[/TD]
[TD]$45.00[/TD]
[TD]-[/TD]
[TD]-[/TD]
[TD]-[/TD]
[TD]-[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TH]6Gbps[/TH]
[TD]-[/TD]
[TD]-[/TD]
[TD]$47.90[/TD]
[TD]-[/TD]
[TD]-[/TD]
[TD]-[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TH]10Gbps[/TH]
[TD]$69.00[/TD]
[TD]$69.95[/TD]
[TD]$63.90[/TD]
[TD]$57.99[/TD]
[TD]$45.00[/TD]
[TD]S$29.99/month (12 months)[/TD]
[TD]S$29.99/month
(12 months)[/TD]
[/TR]
[TR]
[TH]Public IP or CGNAT[/TH]
[TD]Dynamic Public IP[/TD]
[TD]CGNAT[/TD]
[TD]CGNAT[/TD]
[TD]CGNAT[/TD]
[/TR]
[TR]
[TH]Static IP option?[/TH]
[TD]No[/TD]
[TD]No[/TD]
[TD]Yes, $2+GST monthly[/TD]
[TD]Paid option to avoid CGNAT
One time fee of $51.[/TD]
[TD]Yes, $4.03 monthly[/TD]
[TD]No[/TD]
[TD]No[/TD]
[/TR]
[TR]
[TH]ONT/ONR?[/TH]
[TD]ONR[/TD]
[TD]ONT[/TD]
[TD]ONT[/TD]
[TD]ONT[/TD]
[TD]ONR by default, bridging on request[/TD]
[TD]ONR[/TD]
[/TR]
[TR]
[TH]IPv6[/TH]
[TD]Native[/TD]
[TD]Native[/TD]
[TD]Native[/TD]
[TD]No[/TD]
[TD]No[/TD]
[TD]No[/TD]
[TD]No[/TD]
[/TR]
[TR]
[TH]Voice[/TH]
[TD]Free[/TD]
[TD]$10.69/mo add-on
(Current promo rate of $2.14)[/TD]
[TD]Free[/TD]
[TD]Free
$19.50 number porting fee.[/TD]
[TD]$4.03/mo add-on
$51.46 set-up fee.[/TD]
[TD]$3.04/mo add-on[/TD]
[TD]
No
[/TD]
[/TR]
28/10/2024 - Updated with latest data since I was checking for a friend.
Some caveats:
  1. All plans with 24mo contract as base, unless stated.
  2. This table was meant to be a quick and dirty comparison, so all listed prices are for the most baseline plans. This may not include a bundled router for some cases, so please read carefully. There are many permutations because of the way some telcos (Singtel, StarHub, M1, MyRepublic, ViewQuest) try to bundle various options. Some bundles may not be confined to routers, but could be other gadgets or services. Still, since the focus of this is internet plans, make your own choices.
  3. I intentionally left out "secret link plans" or "insider circulation plans". These are publicly available information garnered from the various ISP web sites. Hang around IBNC and see if you can spot some plans. As of today, there are some StarHub promotions that look interesting.
Hope this helps!
PS: Thanks @Dr.Vijay for looking into the edit bug and escalating it to the right channels. And thanks Kok Leong and team for putting a lid on it!
Here is post #13
firesong
Deluxe Member
When you put it all on a table for ease of comparision, it reaffirms that Singtel isn't a good deal at all. In fact, the ISP with the least nonsense and provides everything is M1.
Edit 20241029: This referred to the older table in #10 with more comments. =) The newer one has no updates.
Trying to update the above table by @firesong with more up-to-date info. Also corrected some mistakes.
Last updated on 12-March-2026. For more details please refer to the other posts in this page.
SingTel
StarHub​
M1​
MyRepublic​
ViewQwest​
Whizcomms​
SIMBA​
eight
500Mbps
1Gbps
2Gbps--------
2.5Gbps-----
$26.00 (12 months contract)
3Gbps$39.90 on public website$39.91 on public website. S$29.55 per month special offer.$32.90 for new users. $35.90 for recontract-$40.98 per month, first 12 month $22 OFF.$26.00--
5Gbps$44.90 on public website$45 on public website. S$29.55 per month special offer.------
6Gbps--$38.90 for new users. $47.90 for recontract-----
10Gbps$65.90 on public website$59.34 ($33.59 for CIS or special new user and targeted recontract offer)$29.90 for ONT plan without router for new users.
Recontract at $63.90.
$30.90 for ONR plan.
$32.99 for normal plan, $49.99 for Gamer plan$45.00 with $15 off for the first 10 month.$28.99 (12 months contract)
$28.80 (24 months contract)
$26 (24 months contract, CMLink bundle offer)
$29.99/30days
(12 months contract); $29.99/30days (24 months contract) with free router.
$28.80
(12 months contract); $35.80 (24 months) with free router.
Public IP or CGNATDynamic Public IPDynamic Public IPDynamic Public IPCGNATCGNATDynamic Public IPCGNATDynamic Public IP
Static IP option?NoNoNoPaid option to avoid CGNAT
Yes, $4.03 monthlyNoNoNo
ONT/ONR?ONRONT (Old ONR can be changed to ONT)ONT/ONR
(ONR for 10Gbps ONR plan)
ONTONT or Bridged ONR by default. ONR mode by request, SFP+ ONU option available as a top-upONRONT/ONRONT
IPv6Native (ONR may need to request)NativeNativeNoUpon requestNoNativeNative
VoiceFree$2.18/monthFreeFree
$4.03/month add-on
$51.46 set-up fee.
Free
Free​
No
Notes:
  1. All plans with 24 month contract as base, unless stated.
  2. Please refer to the other posts in this page for more detailed info, including router bundle which may make big differences on the effective price. NLT Charges and Installation Fees may also impact effective pricing.
  3. Short duration offers (eg: from VQ) are not included. Long duration "secrete link" offers are included.
1. As of now (5-March-2026), best value plans for new sign-up in my personal opinion. For recontract, you may have to check out individual thread and check with the respective ISP.
1) Starhub 5Gbps plan at S$29.55 per month with free TP-Link HB710 with S$150 voucher.
2) M1 3Gbps plan at S$32.90 per month with free TP-Link Archer BE230 or RT-BE58U.
3) M1 6Gbps plan at S$38.90 per month with free TP-Link Archer BE805 or RT-BE92U.
4) Starhub 10Gbps plan at S$33.59 per moth with free HB710.
5) M1 10Gbps physical shop offer for new users at S$30.9 per month without router.
Recontract -- it is usually case by case but you can use the above for reference.
I will recommend M1/Starhub to most of the average new users as they are still of better value than SIMBA 10Gbps plan because of the better support.
SIMBA is also using CGNAT without static IPv4 add-on, so it is not a good option for power users either.
MR/VQ may not be so suitable for average new users either because of CGNAT and potential stability issues (especially VQ). Power users may want to consider MR/VQ and opt for the Static IPv4 add-on. VQ also has free /56 static IPv6 upon request.
Singtel usually does not offer good values for new users (even if the new users do not mind using ONR). Power users usually shun Singtel/WC because of ONR.
WC can be considered if the user wants lower cost and do not mind using ONR. But WC support may not be that good for average users.
Eight Home Internet is new. The support may be limited after the first 28 days. So this is probably more for users who do not usually need the support by the ISP.
2. Everyone may have different priorities. So it is better to go to individual ISP thread to ask for more details if you want to hear from the users.
Singtel XGS-PON based plans thread
https://forums.hardwarezone.com.sg/threads/singtel-3gbps-5gbps-10-gbps-enhanced.7030365/
Starhub 5Gbps plan thread which also covers 3Gbps and 10Gbps discussions.
https://forums.hardwarezone.com.sg/threads/starhub-ultraspeed-5gbps-plan-launched.7024290/
M1 discussions (including 1Gbps/2.5Gbps plan and 3Gbps/6Gbps/10Gbps)
https://forums.hardwarezone.com.sg/threads/m1-fibre-broadband-discussion-part-2.5658375/
VQ:
https://forums.hardwarezone.com.sg/threads/viewqwest-fiber-broadband-official-thread-part-6.6473287/
MR:
WC discussions (including 2.5Gbps plan and 3Gbps/10Gbps plans)
https://forums.hardwarezone.com.sg/threads/whizcomms-new-fibre-broadband-provider.5494964/
SIMBA:
https://forums.hardwarezone.com.sg/threads/simba-fibre-broadband.6883466/
Eight Home Internet
https://forums.hardwarezone.com.sg/threads/eight-home-internet-10-gbps.7167676/
firesong
Deluxe Member
@firesong
I have one question with regar to your comments on M1, not so sure if it is correct that "Stability may be location-dependent. Users living in the Northeast region seem to report more downtime".
Check around a few more - EDMW has quite a few reports over these past 2 years, and all seem to be Northeast.
Do a search for "M1 down" on HWZ. ;)
XGS-PON ONT and ONR models for reference, for 3Gbps/5Gbps/6Gbps/10Gbps plans.
Usually the brand does not matter as the performance is similar. Rather it matters whether it is an ONT or ONR. Power users will avoid ONR in general or they will try to bridge it.
1. Starhub users will usually get Nokia XS-240X-A or Nokia XS-140X-A ONT (most likely model in 2026). Existing users may have the Nokia XS-2426X-A ONR (with built-in AX6000 WiFi 6 function) which may have some WiFi issues. You can request Starhub to change to ONT instead if you encounter issues.
2. MR users are reported to get Nokia XS-250X-A, XS-240X-A or XS-140X-A XGS-PON ONT (most likely model in 2026).
3. M1 users will mostly get a Huawei OptiXstar HN8250Ts-20 XGS-PON ONT. M1 10Gbps ONR plan will use a Huawei brand ONR HN8255X6s-8X (with built-in WiFi 6 function).
4. SingTel is using ZTE F8648P or Nokia XS-240X-A XGS-PON ONR. Take note Nokia XS-240X-A can be configured as ONT or ONR, but Singtel configures it in ONR mode.
5. Whizcomms is using the same XGS-PON ONR models as Singtel.
6. VQ is using FibreHome HG5852SA (configured as a bridged ONR by default but you can request VQ to configure it in router mode if you really want an ONR). They have a smaller size Huawei brand ONT (Huawei OptiXstar HN8010Ts-20) as well.
VQ also has an offer of Huawei OptiXstar S800E SFP+ ONU for power users at S$99 extra.
7. SIMBA is using Huawei brand ONT. SIMBA also has a new ONR model.
SIMBA ONT (only one 10G LAN port) -- Huawei OptiXstar HN8010Ts-20.
https://support.simba.sg/hc/en-us/a...e-collected-the-10Gbps-ONT-how-do-I-set-it-up
SIMBA ONU (an ONR, one 10G LAN port and quad gigabit LAN ports) -- Huawei OptiXstar HN8250Ts-20, same as M1 but configured in ONR mode.
https://support.simba.sg/hc/en-us/a...e-collected-the-10Gbps-ONU-how-do-I-set-it-up
8) eigth Home Internet users will get Nokia XS-140X-A ONT, the same model as Starhub.
xRenol
SingTelStarHubM1MyRepublicViewquestWhizzcomms
Plans1Gbps, 2Gbps, 1+1 Gbps Gamer, 10Gbps
Legacy 500Mbps
500Mbps, 1Gbps and 2Gbps500Mbps, 1Gbps and 2Gbps200Mbps, 1Gbps and 1+1 Gbps500Mbps, 1Gbps, and 2Gbps500Mbps, 1Gbps
Static IP option?NoNoNoPaid option to avoid CGNAT, one time feePaid option to avoid CGNAT, one time feeNo
ONT/ONR?ONR, bridging on case by case request.
Legacy: ONT, with VLAN configuration required.
ONTONTONTONT or ONR (Bridging on request)ONR by default, bridging on request
Additional VLAN Configuration required?Yes for legacy plans; 10p0 Internet, 20p4 MioTV, 30 VoIP, 40 ManagementNoNoNoNoNo
IPv6Tunneled through IPv4, limited router supportYes, NativeYes, NativeNoNoNo
Cable TVONR: on any unused port
ONT: Require VLAN configuration
Direct to Internet (connect to router)
Legacy: On ONT port #2
N/AN/AN/AN/A
VoiceFree$10.49/mo add-on*
(Current promo rate of $2.10 until further notice)
FreeFree
$18.99 port-in fee to retain existing number
Free*
No porting in of existing numbers.
$2.99/mo add-on
Additional RemarksONR briging is not a guarantee. Users have reported rejections. Some users have been told by CSO there were additional fees, and there is zero clarifications from SIngtel staff on forums who have seen and acknowledged the problem posting.
SingTel 1+1Gbps plan, only use ONR. The ONR will be configured as three port unbridged ONR ports and one port bridged ONR port, the bridged port does not require VLAN.
Certain users have asked Singtel to provide a special configuration for the ONR with the 1Gbps plan, three ports for SingTel TV only without internet access, one bridged ONR port which does not require VLAN.
Singtel 2Gbps plan: aggregated 2Gbps, must use Singtel ONR, not possible to bridge the ONR
Singtel 10Gbps plan: use XG-PON ONR, 1 x 10G LAN port and 4 x 1G LAN ports.
Starhub 2Gbps plan: ONT port 1 and ONT port 3 used to deliver 2x1Gbps connection, ONT port 2 for Starhub Fibre TV.
Great customer retention policies that are proactive.
Stability may be location-dependent. Users living in the Northeast region seem to report more downtime.Little/no BT throttling
Excellent routing ensures optimal latency
Some questions on stability
Tier 3 ISP under Singtel, so all Singtel restrictions apply, with further deprioritisation. :(
PS: You have something against tables? ;)
I thought M1 provide Static IP at a monthly fee ($2/month before GST) as add-on?
firesong
Deluxe Member
Thanks. Will update.
Can't find the info now without googling for it, and the $2 fee was since 2014, so I'd appreciate if there are any users who can share correct info. :)
firesong
Deluxe Member
Am thinking of updating the table to drop mentions of Legacy details - it's not useful for anyone who wants to sign up for a new plan and do a quick comparison.
