IPhone screen crack - repair advise
sunset80
I have cracked my Ip 11 pro max screen ( touch & display are still good), is it advisable to get the glass panel replaced? Anyone got this done before, will the use experience same as before after the change?
Any shops to recommend, at sembawang / amk area?
Thanks.
reddevil0728
Thanks.
might be worth getting it replaced if not there might be bits and pieces of glass shard that may come off and cut the user
If it is done properly the experience shouldn't be any different.
szeli
Thanks.
my wife got her iPhone 11 Pro glass replaced at Mister Mobile Marsiling
blues7
Thanks.
was just at apple store
screen corner crack - spider web style
doesn't cut finger when using iphone, everything works ok still
doesn't affect the screen visual much since it is at bottom corner
apple staff said consider as change screen, $200+, no apple care, iphone7+
iphone8+ front center button spoil, cannot use finger print sensor anymore, this problem, apple staff said is as good as change the whole phone
szeli
Does Face ID still works after replacement?
Any warning from the iPhone saying that it is not a genuine part or something like that?
for my wife there was a warning inside settings that showed it was a non original part. warning goes away after some time. not sure it was 14 or 30 days..
