Eruditeswine
- Jul 18, 2016
Appreciate the prompt response as always.1. Either one is okay. On the cloud based Pi-hole I use Cloudflared. On the local Pi-hole instance I use Unbound.
2. IMHO thiis is not a good habit, but probably different people have different preferences. Electronics product especially the power supply, have inrush current which may stress the front end components every time you turn it on. So the life span may be reduced.
If you are worry about SD card (or USB drive) corruption, then it is probably better to shutdown the Paspberry Pi first before shutdown other things. That being said, no need worry too much either, just duplicate your SD card (or USB drive) so that you have a backup. If the thing got corruptted then just pop in an other one.
Remember to back up after finishing the setup and when you change some settings. Then it is very easy to import the settings (including the adlists) by using the teleporter restore function.
1. After using both, which do you prefer?
2. So you leave your network on 24/7 just like refrigerator, washer and similar appliances?
Thanks for the head's up on backup.
