Cheap phone with NFC
xonix
Define “cheap”
$1000 is peanuts to a billionaire
yusoffb01
recommend means there are many to choose from with a given budget.
firesong
Deluxe Member
I don't think $150 can barely get a low spec brand new phone... Let alone with NFC...
Same thoughts. Doubling it to $300 would widen the scope reasonably, especially if "Brand new" is the requirement.
If "used" is okay, there are plenty of choices - Samsung S8? Huawei Mate 9? :s13: And quite a few other options, including broken screen phones going "cheaply" on Carousell.
free2d
I saw Samsung M22 and M32 around $250-$300. Different only camera.
Are there anymore similar better ones?
ZrE0_Cha0s
den how better you want ? maybe u can add on a few of the requirement on top of what u already wanted (NFC).
mosmos
High Honorary Member
i bought at $165 qoo10, 5G with NFC
Amuroraysg
Qoo10 got sell LG v50s for 139 flagship of yesteryear..
bought one for nostalgia value and spare phone.
kazuki666
Actually any reason why TS needs NFC? Else your choices can be wider at the budget
