Google Pixel Update - Android 12 July 2022
limmk
Google Pixel Update - January 2022
Software versions
Global
  • Pixel 3a (XL): SQ1A.220105.002
  • Pixel 4 (XL): SQ1A.220105.002
  • Pixel 4a: SQ1A.220105.002
  • Pixel 4a (5G): SQ1A.220105.002
  • Pixel 5: SQ1A.220105.002
  • Pixel 5a (5G): SQ1A.220105.002
What’s included
The January 2022 update includes bug fixes and improvements for Pixel users – see below for some notable improvements.
Framework
  • Fix for issue causing screen to unlock after missed call when no screen lock is set *[1].
Network & Telephony
  • General fixes & improvements for network
  • Fix for issue preventing emergency calls in certain conditions while some third-party apps are installed *[4].
Power
  • Fix for issue preventing Pixel Stand setup to start after updating apps in certain conditions *[2].
System
  • Fix for issue causing incorrect data usage accounting in Network menu on some networks *[1].
User Interface
  • Fix for issue causing a black frame to appear when dismissing the Assistant overlay on the lock screen
  • Fix for issue causing memory leak in system UI under certain conditions *[1].
  • Fix for issue causing navigation bar to be hidden when switching device orientation in certain conditions *[1].
  • Fix for issue causing PIP window to render incorrectly for certain apps *[1].
Wi-Fi
  • Fix for issue causing Wi-Fi network to drop connection in certain conditions *[3].
Device Applicability
*Updates for PIxel 6 and 6 Pro are delayed until later in January, as noted above
*[1] Included on Pixel 3a, Pixel 3a XL, Pixel 4, Pixel 4 XL, Pixel 4a, Pixel 4a (5G), Pixel 5, Pixel 5a (5G), Pixel 6 & Pixel 6 Pro
*[2] Included on Pixel 4 / XL, Pixel 5, Pixel 6 & Pixel 6 Pro
*[3] Included on Pixel 6 & Pixel 6 Pro
*[4] Included on Pixel 3, Pixel 3 XL, Pixel 3a, Pixel 3a XL, Pixel 4, Pixel 4 XL, Pixel 4a, Pixel 4a (5G), Pixel 5, Pixel 5a (5G), Pixel 6 & Pixel 6 Pro
Details of security fixes are found in this link :
https://source.android.com/security/bulletin
Get the latest Android updates available for you
  1. Open your phone's Settings app ⚙️
  2. Near the bottom, tap System 🔒
  3. Tap System update 📱
  4. You'll see your update status. Follow any steps on the screen
Depending on your network connection speed and number of apps involved, this will take about 25-50 minutes.
Reboot the device after taking the update.
Factory Images for Nexus and Pixel Devices
Full OTA Images for Nexus and Pixel Devices
Android Security Bulletin—January 2022
Pixel Update Bulletin—January 2022
limmk
Pixel 3 series is also getting a 491KB update
According to the changelog, it just fixes a bug that can prevent emergency calling. The security patch level is still from October 2021.
firesong
Deluxe Member
Still there leh
Can't get the Dec 1 Google Play update on my 4a. It's still on Nov. But Security Update is up till SQ1A.220105.002.
Not sure what changed, or if it's for other models.
limmk
https://support.google.com/product-documentation/answer/11412553
January 2022
Critical Fixes
[Tablet, Wear OS, Phone] Bug fixes for device connectivity, safety & emergency, system management & diagnostics and media related services.[1]
Google Play Store
Play-as-you-download feature to let gamers start playing mobile games while the app download continues to reduce waiting times. [3]
New Features to help you discover the Apps & Games you love.[3]
Optimizations allowing faster and more reliable download and installation.[3]
New features to the Play Pass and Play Points programs. [3]
Enhancements to Google Play Billing. [3]
Continuous improvements to Play Protect to keep your device safe. [3]
Various performance optimizations, bug fixes and improvements to security, stability and accessibility. [3]
System Management
With updates to the timezone management system, added support for new daylight savings time transition changes in various countries.[1]
Updates to system management services that improve device connectivity, network usage, stability, security and updatability. [1]
[1] Available through Google Play system update for January.
[3] Available through Google Play Store v28.7 updated on 01/06/2022.
limmk
Google’s critical Pixel 6 January update is eariler than expected
The January security patch rolled out normally at the start of the new year for all other Pixel phones, and is now making its way to the 6 and 6 Pro:
Pixel 6/Pro January patch​
Framework
  • Fix for issue causing screen to unlock after missed call when no screen lock is set.
Network & Telephony
  • Fix for issue preventing emergency calls in certain conditions while some third-party apps are installed.
Power
  • Fix for issue preventing Pixel Stand setup to start after updating apps in certain conditions.
System
  • Fix for issue causing incorrect data usage accounting in Network menu on some networks.
User Interface
  • Fix for issue causing memory leak in system UI under certain conditions.
  • Fix for issue causing navigation bar to be hidden when switching device orientation in certain conditions.
  • Fix for issue causing PIP window to render incorrectly for certain apps.
Wi-Fi
  • Fix for issue causing Wi-Fi network to drop connection in certain conditions.
limmk
Google Play system january update​
Also lastest google play services 21.48.55 and play store version 28.9.12-21 available
limmk
Google Pixel Update - February 2022
Details of this month’s security fixes can be found on the Android Security Bulletin:
Software versions
Global
  • Pixel 3a (XL): SQ1A.220205.002
  • Pixel 4 (XL): SQ1A.220205.002
  • Pixel 4a: SQ1A.220205.002
  • Pixel 4a (5G): SQ1A.220205.002
  • Pixel 5: SQ1A.220205.002
  • Pixel 5a (5G): SQ1A.220205.002
  • Pixel 6: SQ1D.220205.003
  • Pixel 6 Pro: SQ1D.220205.003
What’s included
The February 2022 update includes bug fixes and improvements for Pixel users – see below for details.
Camera
  • Fix for issue causing device reboot when using camera in certain conditions *[1].
Bluetooth
  • Fix for issue causing audio playback to disconnect while using certain Bluetooth devices *[1].
  • General improvements for Bluetooth audio quality with certain media codecs *[1].
Framework
  • Fix for issue causing keyboard to display over input text in certain conditions *[2].
Telephony
  • Connectivity fixes for specific carrier networks *[3].
*[1] Included on Pixel 6 & Pixel 6 Pro
*[2] Included on Pixel 3a, Pixel 3a XL, Pixel 4, Pixel 4 XL, Pixel 4a, Pixel 4a (5G), Pixel 5, Pixel 5a (5G), Pixel 6 & Pixel 6 Pro
*[3] Included on Pixel 4, Pixel 4XL, Pixel 4a (5G) & Pixel 5 (C Spire, Cellcom)
Android Security Bulletin—February 2022
Pixel Update Bulletin—February 2022
