Xperia 5 III
Charles_Chi4
Anyone has overheat and fast battery drain issue? Mine is quite hot some time and the battery can't last half a day even I enabled stamina mode.
Toader
What application you put at background? Any games / Google drive /Google sheet / presentations?
Charles_Chi4
Only social media apps, no google drive, no game.
Yesterday i did repair with xperia companian tool, and restored all the apps but haven't used all the apps yet. So far so good, no more overheat.
I tried opening 1 app at a time and get it shown in battery usage list and restrict the usage in background.
Mystyque
Yakumo
Anyone having issues with tracetogether app randomly launching in the background even after killing the app and bluetooth turned off?
Persia
can anyone help with this issue:
cannot connect my 5iii to my pc
installed the xperia companion, but the phone is not detected
Toader
Close unnecessary applications to free up ram, reboot should be better. Use only the able Sony provided, or, your USB cable might be faulty, connect to the strongest USB port (if the USB port has blue tongue that's the one to connect to ) also remember to free up your PC ram (same as mobile phone . Best to reboot too)
xonix
If I recall correctly, Sony phones USB to 3rd party device connection is disabled by default. There should be a toggle in the settings menu to enable it briefly. Under USB connection or connectivity ?
faridcooper
Automatically updated on my 5 III now on 61.1.A.2.211
Some getting used to the changes. Random lags once in awhile but otherwise it's fine. Not digging the pulldown notification buttons
Blitzy
anyone found out how to re-assigned/disable the Google Assistant Button after upgrading to Android 12?
