VIVIFI
hereiam7788
U would rather just pay for the delivery charge in the first place and save all the troubles. even taking public transport to the venue to collect also need mrt/bus fares which min $2 for two ways depending how far away u are.
vsvs24
Sometimes collect earlier than available delivery date.
May not cost much more eg collect on the way from work etc.
His case of 3 times vivifi staff not there a bit weird.
roborovsky
Confirmed triple guarantee. Even took photo with my watch & send to them.
The first at Bishan maybe can suspect timing, but second & third jurong/Serangoon made sure timing is correct.
Bishan self collection only available on 14th Jan.
And when did you go Bishan to collect?
vsvs24
RLWZ21
well sadly this is how vifii do for their collections point, unless they will have a shop like tpg....
steven168z
you are wrong.. this method is good especially it cover most of the mrt station just need to see the timing and go there...
vsvs24
This is a good option. Better than to have shop at far away location.
So far I have collected twice without issue. So have many others. Should not condemn it just because of 1 complain.
Kitaro9202
Yup either you self collect and if you cannot make it den you opt to pay for the delivery to your doorstep
gapboy
good and bad.. permanent shop front for collecting SIM in each part of SG region will be ideal too like some MVNO ... i.e redone can be collected at challenger and some mobile shops.. But ideally free delivery is the best option like GOMO or ex-GRID
vsvs24
I would rather they save the rental cost and give low price. After all you only need to collect SIM card once....
Don't want them to close shop like Grid.
hereiam7788
not enough den buy booster ;)
yeah. will monitor and see how. since this is my first month with vivifi also.
I did not purposely save or use the data which it should tell my actual usage monthly.
should have enough though I guess. haha.
JustDoLor
ViviFi got no apps, right?
So only can use browser. If want to check usage need to login. Can I ask:
1.) every time I need to key-in user_ID and pwd?
2.) I need to navigate the menu, make a few taps then can see the usage?
Just to check ease of use for seniors.
Thanks
gapboy
Thanks
i don't even check vivifi dashboard often ... when you get low data alerts via sms (which hardly over use for me) . Just login bookmark the vivifi page dashboard i.e https://family.vivifi.me/dashboard/local easy peasy
RLWZ21
Thanks
yes. no apps.
1) yes, unless u saved those details on browser.
2.) as gapboy mentioned set a bookmark on your browser homepage. so everytime u open can quick access to it.
