occifer
- Mar 9, 2018
Normal Jap car. Toyota, honda, nissan, etcDepends what your car is lo
Do you drive or have a car?Wouldn't the air escape immediately?
Since it is a flat, there is a hole somewhere?
Well mine doesn't have a battery.... Runs solely on car battery, aka cigarette lighter socket
New tyre for those still costs $150-200 each. And must change two at one go. This $20-30 device can save your wallet.Normal Jap car. Toyota, honda, nissan, etc
IMHO.Noted. And can always pump 10kpa higher?
If the nail is still there, the air will leak at a slower pace.
Yeah this is better.
IMHO.
Do note that the better tyre pump requires higher current. Some cigarette lighter socket max current is limited.
I bought at autobacs years ago...still works fine....as I pump my kids bicycle tyres every week....not sure if they still have....Yeah will be getting one. But car lighter version.
It's a matter of time. Lower current for lousier tyre pump will still get the job done. Enough to drive to Paya Lebar or Balestier/Lavender (2 of the late night tyre shop area in SG)IMHO.
IMHO.It's a matter of time. Lower current for lousier tyre pump will still get the job done. Enough to drive to Paya Lebar or Balestier (2 of the 24/7 tyre shops in SG)
IMHO.I see. So is juz a few mins more of pumping.
Longer pumping time is fine.
It seems car lighter uses 10/15/20 fuse amp....from wat i googled.
Under 1500cc cars may just use 10amp.
Portable air tyre is a great idea but I dislike the idea of a power bank or battery left in the car.
Alternative is to get runflat lo.
But they are useless if you do not have a tyre pressure monitor in your car.
And they are godamm expensive.
IMHO.
These days, a TPMS is a must. A tyre at 160 kPA will look similar to a 200 kPA tyre.
