Does anyone actually buy portable air pump for car?
4_dreamz
Architeck
IMHO.
Do note that the better tyre pump requires higher current. Some cigarette lighter socket max current is limited.
It's a matter of time. Lower current for lousier tyre pump will still get the job done. Enough to drive to Paya Lebar or Balestier/Lavender (2 of the late night tyre shop area in SG)
keenklee
It's a matter of time. Lower current for lousier tyre pump will still get the job done. Enough to drive to Paya Lebar or Balestier (2 of the 24/7 tyre shops in SG)
IMHO.
If unchecked, there is a possibility of blowing the fuse - no outcome.
occifer
I see. So is juz a few mins more of pumping.
Longer pumping time is fine.
It seems car lighter uses 10/15/20 fuse amp....from wat i googled.
Under 1500cc cars may just use 10amp.
Portable air tyre is a great idea but I dislike the idea of a power bank or battery left in the car.
sunsetbay
Moderator
Moderator
I have the Xiaomi one~ helped my colleague to pump his flat tyre~ initially he asked for the tools to replace spare tyre then I lent him my air pump, which save the trouble to replace spare tyre under the hot sun~ :s22:
Architeck
Alternative is to get runflat lo.
But they are useless if you do not have a tyre pressure monitor in your car.
And they are godamm expensive.
keenklee
IMHO.
I have a tyre pump that indicates 150W and 14A. 🤣
If pump only a single tyre, usually it is not a concern.
If pump all 4 tyres, have to read the specification for "rest" time.
There are certain areas in the car that is cool even under hot sun.
occifer
I juz googled that tyre tech.
Nice but ya no point if no tyre pressure monitor and not worth the cost wor
keenklee
IMHO.
These days, a TPMS is a must. A tyre at 160 kPA will look similar to a 200 kPA tyre.
