darkmatt
- Oct 9, 2006
finally.. but put what? just disable sua lolSeems like Android 12 might be able to let us customize the useless Google Assistant physical button.
I'd love to toggle NFC via it if possiblefinally.. but put what? just disable sua lol
What application you put at background? Any games / Google drive /Google sheet / presentations?Anyone has overheat and fast battery drain issue? Mine is quite hot some time and the battery can't last half a day even I enabled stamina mode.
Only social media apps, no google drive, no game.What application you put at background? Any games / Google drive /Google sheet / presentations?
1. From the task manager, there is a screenshot utility that will capture the windows currently selected. Alternatively you can download a app that has a floating icon to capture screenshots https://play.google.com/store/apps/details?id=com.mdiwebma.screenshot
Close unnecessary applications to free up ram, reboot should be better. Use only the able Sony provided, or, your USB cable might be faulty, connect to the strongest USB port (if the USB port has blue tongue that's the one to connect to ) also remember to free up your PC ram (same as mobile phone . Best to reboot too)can anyone help with this issue:
cannot connect my 5iii to my pc
installed the xperia companion, but the phone is not detected
If I recall correctly, Sony phones USB to 3rd party device connection is disabled by default. There should be a toggle in the settings menu to enable it briefly. Under USB connection or connectivity ?can anyone help with this issue:
