iPhone 13 Series
chopra
hi all. previously my android phone can detect ezlink card. but after using iPhone, I can’t do it anymore. how do i activate NFC in iPhone actually?
with the same setting, I can use apple wallet n tap at ntuc or at bus, so this is v puzzling
Read HWZ Forum Rules!
Habrosus
Which model iPhone? Which version iOS?
I don't remember having to activate NFC on my iPhone XS Max, and iOS has always been the latest. No issue detecting my card so far.
chopra
ip12. i place my ezlink card below the back camera, cannot sense. i shift to other parts of the back (basically I move the card slowly around), also cannot detect.
Habrosus
iPhone 12 with that bigger camera... Try somewhere bottom-right of cam area, hold it there for a few seconds and see what it says on the screen. It should be somewhere there, hold it steady for a while especially if you happen to have a case there.
Habrosus
ya!!! android nfc can leh….
Try this... Once you've estimated the position, stop moving the phone for a while and see if it detects your card. Having come from an Android being my primary phone, I've noticed my old iXSMax isn't as sensitive. Have to slow down as it takes more effort/time. I thought it's my iPhone that's ready to be replaced...
RocketBunny
The nfc is at the top edge or beside the camera area if im not wrong
Mostly use to top up my nets flashpay card or check balance
Habrosus
ready to scan popped out. yes. and it just stays there forever as i shift my card ard the back.
I've never tried FlashPay before... With EZ Link cards, I've to get them entered into the app first. That is, I cannot help friends reload as their cards aren't in my app.
Not sure if that's the reason...
chopra
hai ok. will try ezlink next time.
just to confirm, unlike android where nfc can be activated or inactivated, iOS is permanently activated hor?
zwchia
Flashpay gotta use the NETS App. The EZ-link app is not compatible. At least that was my experience.
Habrosus
Oh, we can reload with the app then! Come to think of it, I've a forgotten EZ Link charm that's a FlashPay, forgotten because the number wasn't accepted in the EZ Link app. Out of sight, out of mind.
Thanks for this, I'll go use my NETS app with it. 👍
