- Sep 16, 2018
To summarize for year 2025/2026 (updated on 14-Sept-2025)
Please also go to Page 7 for some updated info about SOC (TV Box Chipset) comparisons.
https://forums.hardwarezone.com.sg/threads/android-tv-box-recommendations.6662455/page-7
Basically you can consider the following.
1. Get certified Google Android TV OS devices which are also certified by Netflix: Mi Box S Gen 2 or Mi Box S Gen 3 (highly recommended), Google TV Streamer 4k (2024 model), Google Chromecast 2020, Mecool KM2, KM2 Plus, KM2 Plus Deluxe and KM7 Plus.
Mi Box S Gen 2 is a good upgrade from Mi Box S in terms of the upgraded S905X4 CPU and Google TV OS. It also adds the support of Dolby Vision and Dolby Atmos.
https://androidpctv.com/xiaomi-tv-box-s-2nd-gen-review/
Mi Box S Gen 3 is a good upgrade from Mi Box S Gen 2 in terms of the slightly upgraded S905X5M CPU and 32GB Storage.
https://androidpctv.com/xiaomi-tv-box-s-3rd-gen-review/
There are a few other choices as well, like Mi TV Stick 4K (2nd Gen), Realme 4K Smart Google TV Stick and Mecool KD3 4K TV Stick.
Mi TV Stick 4k Gen 2: same S905X5M CPU as Mi Box S Gen 3.
https://androidpctv.com/xiaomi-tv-stick-4k-2nd-gen-review/
Or if you want to pay for the best Android TV box, get Nvidia Shield TV 2019 for streaming. If you are into gaming as well, get Nvidia Shield TV Pro 2019.
I tend not to recommend 1080p TV sticks like Mi TV Stick 1080P and Mecool KD5 or Google Chromecast HD (2022 model), they are okay if you use the built-in apps. If you add more apps the 1GB RAM can be the limiting factor.
You may also want to look at onn. Google TV 4K Pro (2024 model) and onn. Google TV 4K Streaming Box (2023), especially if you can get good Black Friday deals.
2. Consider the boxes mentione in Point 1 again if you are first time buyer.
3. If you only need Netflix but not Chromecast, and you want to get a powerful box, get Amazon FireTV Cube 3rd Gen (2023 model). Amazon FireTV Stick 4K 2nd Gen (2023 model) and 4K Max Gen 2 (2023 model) is also a good buy.
4. If you do not need Netflix HD, you can also consider official Android TV OS box (but lack Netflix certification) like Mecool KM6 (S905X4 based) or KM7 SE (S905Y4 based). They support Chromecast.
When you do not need an Android TV Boxes?
1. You have an Android TV OS based smart TV (eg: Sony smart TV), and the performance is okay.
2. You have a smart TV from Samsung/LG and yet you do not feel the limitation from the lack of apps.
3. Apple TV owners. Apple TV is a very good TV box, especially if you are into Apple ecosystems.
