[Recommend] Good Mechanical Keyboard
FroztSpectre
Probably going to change my bottom keyboard to Red Samurai, so I'll have matching keyboards.
eyz
does anyone how this wired/Bluetooth switch works?
FroztSpectre
What model is this? ur full size kb seems small and i like it!
China-brand keyboard.
Top one is SKY980 from taobao. Paid RMB204 for the barebone kit.
商务黑半成品套件[SKY980有线单模] | 套餐类型:官方标配
https://item.taobao.com/item.htm?spm=a1z09.2.0.0.725b2e8d04esLb&id=644528474829&_u=621jl6d6bce7
Bottom one is is some brandless kit from taobao. Currently RMB299 for the barebone kit.
940RGB三模套件+升级包 | 套餐类型:官方标配
https://item.taobao.com/item.htm?sp...mhdn4&id=644143105349&ns=1&abbucket=16#detail
Personally prefer the second one.
First one no "Home", "End", "Print Screen", "Scroll Lock" shortcut functions.
Second one can press Fn+(key) for those shortcuts.
And second one has Bluetooth, 2.4g and wired version as well.
FroztSpectre
nez
Both keycaps were direct from Akko's Tmall store.
It's not GMK's keycaps. It's Akko's own version of the Red/Blue Samurai, with ASA profile.
Akko Red+Blue Samurai: Paid RMB299 Yuan, 226 keys
https://detail.tmall.com/item.htm?id=652291713101&spm=a1z09.2.0.0.6f122e8daldmbk&_u=621jl6d6bb8b
Akko ASA Midnight: Paid RMB249, 178 keys
https://detail.tmall.com/item.htm?id=637411065549&spm=a1z09.2.0.0.6f122e8daldmbk&_u=621jl6d63204
oh. ok. Thanks. I like the blue samurai. But never pull the trigger when became available.
caesium2108
Thx! Second one as in the bottom one?
RLWZ21
hey guys just checking if there is any other brands beside razer having optical keyboard? if anyone know if there is a cheap yet decent enough one out there?
FroztSpectre
DIY.
I recall Gateron produces Optical switches as well (keychron carries certain keyboard models with those i think). Not sure about other switch manufacturers.
Edited:
Must clarify also. Custom keyboard PCB must be able to support optical switches. The standard mechanical ones you see out there won't be able to use those optical switch.
A quick google shows Epomaker has optical switches keyboard as well, but similarly the switches are from Gateron.
RLWZ21
DIY.
Edited:
haha, den like this gg lol. i mean that i have to do a lot of reseach but also the research probably not much result since u mentioned like only 1 company that has optical switch.(beside razer)
but i dunno how well they compare to razer though and next to it i mean a lot of reviews pointing how optical switch is even better than medical switches and i have not tried a optical switch before so its hard to tell how much better is optical. (but also quite curious to try optical as well :p)
purpleberry
first keyboard that I did
1) TM680 $51
2) XDA Keycaps from Shopee $27
3) Jwick Ultimate Blacks( Pre-lubed ) $25.90 for 70pcs
$104 KYM?
This is nice but now the price for the board is like $130? Does it come in cherry pink? Can only find outemu mute switches.
What version of BT is that?
purpleberry
Anyone tried Leopold keyboards, especially 60-65% bluetooth? How are they like compared to Filco, Keychron, Ducky, etc.?
